Old 11-27-2005, 09:57 PM   #1
HeavyD
HeavyD's Avatar
Anyone use a 67-72 to haul a car trailer??
I am thinking of buying a car trailer and was wondering if a 67-72 1/2 ton would be a decent pull truck for this purpose. Is a 1/2 ton enough, or should a 3/4 ton be used? I know a diesel is best but I really don't want to buy one at this time. Never towed anything so this is all new to me. Thanks for any input.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 11-27-2005, 10:03 PM   #2
texascowboy593
texascowboy593's Avatar
Re: Anyone use a 67-72 to haul a car trailer??
I used my 1/2 ton to pull another 1/2 ton couple of months ago... Pulled pretty good. Just make sure your brakes are good or else... Ihave a 350/350 combo in the red 71 and its bored 60 over. 100 mile trip on an 80 degree day at 60-70 mph did fine
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 11-27-2005, 10:28 PM   #3
racer face
1/2 ton will do if the truck is set up for towing. I'd wire electric brakes up, specialy if pulling in hills. 1/2 ton brakes will heat up fast in hills. I'd prefer 3/4 or 1 ton, which I own the lader,68 1ton dually.
Pat
______________________
1968 1 Ton Dually Flatbed 327/th400
1968 C30 Open Road 327/th400
1997 F350 CREWCAB 4X4 460 BIGBLOCK
racer face is offline   Reply With Quote
Old 11-28-2005, 12:02 AM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Dalton, a 1/2 ton should be fine, just make sure you have a good hitch system and trailer brakes are good too! My 70 is a little "touchy" in the brake department, but i have a new disc setup for the front that should help. Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 11-28-2005, 03:02 AM   #5
HeavyD
HeavyD's Avatar
Well, it looks like I may be able to use my GMC as a hauler. Thanks for the pics guys.
Old 11-28-2005, 12:01 AM   #6
72MARIO
72MARIO's Avatar
I am planning on taking the 67 down south and pulling a 67-72 1 ton back with it.. I am going to use a dolly though. I dont see a problem with it. A 1 ton pulling would be ideal but that's all I got to pull with so it will have to do.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-28-2005, 10:24 AM   #7
StingRay
StingRay's Avatar
Dalton, I regularly pull just under 9000 lb (trailer plus load) short distances when I haul my water and it handles it very well. I wouldn't want to do it on hilly terrain though. At around 5-6 thousand pounds it is an easy pull here on the prairies. Good brakes on truck and trailer as well as a good controller and a solid hitch, ball mount and ball all of the correct rating are a must. Proper loading of the trailer and 10-15% of the weight on the hitch is imperative. If not properly loaded you can end up upside down in the ditch really fast. If you have ever hooked onto a tail heavy trailer you know what I mean.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 11-28-2005, 06:49 PM   #8
too much stuff
Roadtrip!
Just don't let THIS happen to ya. Looks like he had a good hitch system, just not good driving techniques!!!
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 11-29-2005, 01:19 AM   #9
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Thats a bad day!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 11-29-2005, 12:59 AM   #10
meathead95
computer illiterate
meathead95's Avatar
i pull mine all the time with my 2wd blazer
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
