12-20-2005, 11:25 PM | #1 |
Muncie
I currently have a 65 GMC with a 454 and a turbo 350. What will I need to install a Muncie M22 besides the transmission, money, time, and a new drive shaft?
65 SWB 454 350T |
12-21-2005, 01:23 AM | #2 |
In Progress
Re: Muncie
manual tranny pedal assembly
1993 Chevrolet K2500 454 4L80E 1974 GMC 1/2t 2wd Stepside 305 auto *sold* 1985 Ford Mustang GT 5.0 5spd |
12-21-2005, 12:33 PM | #3 |
Re: Muncie
Is there a kit I can buy?
65 SWB 454 350T |
12-21-2005, 05:56 PM | #4 |
In Progress
Re: Muncie
you will most likely have to go to a junkyard
12-22-2005, 12:19 PM | #5 |
Prestige member Old Farts Club
Re: Muncie
a good clutch to last behind the big block, is that the rock crusher trans? it should be about the same length as the 350 ,watch the spline count on input and output shafts might be different on a rock crusher.is the motor drilled for pilot bushing/bearing? flywheel bellhousing starter maybe different.It's worth the work for play factor, gets tiresome on a daily driver.
Hey sombodys gotta do it! |
