STOP! Hamma time!!!
Well it was all good during the summer. But when a cold spell came through in Nov. I got caught slippin. It was below freezing for about a week and I raise my hand as say I did it… “I did not confirm that I had enough antifreeze in the truck”!
![]() ![]() Well….Game ON!!!! ![]() My don’t list: Don’t want a BB. “ “ “ a SB bigger than a 400. “ “ “ another 305 “ “ “ change to Carb “ “ “ change to TPI “ “ “ older model SB “ “ “ nothin but a chevy Why the limitations and being picky, Well….. I’m on a budget, need a quick and easy drop in, want to keep moderate MPG, and I want to upgrade while I have the opportunity. So lets have it!!! Teach me somethin new! What would you do? Thanks in advance.
Plan your work and work your plan!!!, or pitty da fool!! ![]() 87 GMC BaseTrim, 305 under the wrench/TH400/ 92 Chevy 1500, 350,TH700R4 sittin on dubs |
Trucker.
Re: It's a fact, my engine is cracked
TBI was 87-95, Vortec was 96-98(99/00 on the SUV's).
STOP! Hamma time!!!
Ok.. But could you not use TBI on a Vortec engine or is Vortec strictly TPI?
STOP! Hamma time!!!
duh!!! I knew the answer to my own question. Bigarmzz is selling just the part I would need to get away with TBI and Vortec combo. I gotta get more sleep. Thanks Izzy, now I know where to start looking.
yeah, you can run a newer vortec motor in your truck, no problem..
you just need the big ol' $$$ intake that gmpp makes, or you could use a carberated intake and use an adapter (although i really dont recommend that) check out this web site http://thirdgen.org/techbb2/forumdis...?s=&forumid=17 that link should take ya to there "tbi tech board", its for third generation camaro's, but the same concept applys good luck man! ![]()
1987 350 TBI lowered 5/7 |
Slots go on anything!
I looked into doing the same thing to my 90 Suburban. I found a couple 350 Vortec engines around here for $750. I figured I would have $1100-1200 in it by the time i picked up the intake and built the EGR valve.
You can also pick up a 350 premium long block at Blaines for $640 + core. I put one in my 87 SWB I had a couple of years ago, and it still runs great. They usually try to hose you on the core, but a full core charge is only $400. They come with a 12/12 warranty, too. If you need any help with the swap and whatnot, I am in Arlington.
1974 Jimmy- 5.3/4L80e/NP241 |
STOP! Hamma time!!!
Thanks Jonboy, for the info. I'll look into Blaines for the block. I'm not confident in the junkyard engines, unless I going to rebuild it. I have no time for that or traveling to south Texas to mess with Scroggin Dickeys. In my hood, I can't pull/replace an engine without HOA breathing down my neck or I would definitely take you up on a helping hand. I'll just have to pull it to the country in Tyler Texas where I got access to air tools. I got some more upgrades to make like dropping it, installing a 700R4, replacing the suspension and disk break job. I’ll have to wait until spring to jump on it.
Anyone else, who can offer more helpful info, would be greatly appreciated.
