WTB this ad
New exhaust w/6" drop pics
I have seen requests for pictures and info for this several times so I thought I would put up a couple pictures. The exhaust is 2.25" aluminumized tubing. I used the ECE trailing arm crossmember (thought I took a pic of the pipe running through it but apparently not). The pipe goes over the trans crossmember and through the trailing arm crossmember. I also had a balance tube installed. I asked about a X pipe but he just didn't think he could make it happen and remain above the height of the framerails. Here are a couple shots from the side just to show that nothing is below the framerails.
![]() ![]() Here's the balance tube. ![]() I had him stay outside of the rails after the axle in case I ever want to go back and add a rear fuel tank. ![]() The driver's side was tight! We had to take the bolt out of the track bar and turn it around (face the head towards the front of the truck) in order to make room for the pipe. ![]() ![]() The passenger side wasn't near as bad. ![]() And of course the tips! ![]() |
Junior Member
![]() Join Date: Jul 2005
Re: New exhaust w/6" drop pics
Wow, I like that. I didn't think you could have a 6" drop without cutting the frame out for the axle, let alone squezzing in the exhaust through there. Cool!
1971 Short Stepside,(sold) 2011 Caprice PPV 1950 Chevy Fleetline Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=302759 |
sweet, i like that
Any contact with the suspension cycling? Looks like there might be.
Looks good, I hope I can get similiar work done! Last edited by FormerMember; 02-01-2006 at 08:15 PM. |
#5 | |
WTB this ad
Looks Great! Are you using headers and if so what brand and p/n?
78 C10 LWB Super Cheyenne |
#7 | |
WTB this ad
![]() Join Date: Aug 2004
see ten- what headers are you using? or stock exhaust manifolds. Would you strongly recomend an ece trailing-arm cross member for a 4/6 drop THANKS. JOHN
#9 | |
WTB this ad
thanks for taking the time to get pictures, I do appreciate it! good tip on the one piece driveshaft, I didn't realize that. Since I just had my two piece balanced with all new u joints and the carrier bearing replaced I guess i'll be staying with the stock trailing arm crossmember for a while. oh well, thanks again. Steve
Some guys go outside the frame just before the rear hump in the frame and then run the pipe up and over the axle in the wheel tub. It gives great clearance and less severe bends in the pipe, yours looks nice, not baggin' on you just adding another option at there.
Active Member
![]() Join Date: Dec 2005
Great install. Very clean. I'm more and more impressed with ECE part all the time.
The older I get, the faster I was!! |
someday it will be done!
Looks great see ten!
I notice you didn't c-notch the frame and I don't see any bumpstops. Just wondering if you've had any probs with bottoming out?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#14 | |
WTB this ad
#15 |
Out of the carpool lane.
That's awesome and thanks for posting pics. I nominate this for the FAQ section!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
#16 |
Jamie Hyneman is my twin
![]() Join Date: Nov 2005
Fantastic. That is some smooth work. I'd bag it myself.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
#17 |
![]() Join Date: Feb 2000
Clean install.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#18 |
![]() Join Date: Jan 2004
Looks great see ten! Crawl up under there and get me a pic of that crossmember. I'd like to see that part of it, I'm debating on putting that crossmember on my burb. Thanks for the pics.
My Suburban Project 72 Suburban 68 SWB 57 Belair 55 Cameo 06 Chevy 1/2 ton crew 09 Suburban |
#19 |
Junior Member
Hi, I have a 72 C-10 that I am dropping 5 inches and would like a pic of your truck to see what it looks like, thanks. Jim
#20 | |
WTB this ad
#21 |
Nice Ride!
I made a 2 1/2" system out the rear with ECE 6" drop. I had to go under the trans crossmember, I kept it tight it only shows about half the pipe under the frame from the side. I made the Whole system using flowmaster universal tail pipe kits, and H pipe. Flowmaster 50 series deltaflow stainless. check it out. This is the first time posting pictures..... |
#22 |
A.K.A- Crummy
I like it. Looks like it took some time to figure out.
2003 Silverado Z71 Are fishermen all liars? |
#23 |
WTB this ad
Here are a couple pictures of the truck for those who asked. I will try to get my buddy to bring his camera by tonight so I can get a picture of the ECE crossmember. The man who ran the tubing for me has about 30+ years of experience. He has actually stopped doing this kind of work due to health reasons. I called him to see if he could refer me to someone and he told me he had access to a shop to do jobs for his "old customers". If you didn't notice there is just one piece of tubing from the mufflers to the tips(nothing pieced together). He came off the manifolds with 2" pipe and when he got it parallel to the frame he went up to 2.25". He took his time on this job and was happy with how it turned out. It cost me all of $220 which I feel was a bargain. (These photos were made before I had the exhaust ran which is why you don't see the tips.)
#24 |
The LuvShack Garage
Looks good ASA
#25 |
Wow how thick is the plate on that Xmember?It looks real beefy (5/16-3/8) in those pics!
