Old 02-06-2006, 04:52 PM   #1
shelby987
shelby987's Avatar
wtb: eaton 3rd
I think I may have posted this before, but thought a follow up might be due. I am trying to find an eaton 3rd with 4.10's and a posi setup. I have a 4.56 with an open rear.....and after sometime in the mud this weekend, I would like to upgrade. If you are willing to ship let me know, otherwise, please be within a reasonable driving distance.
Thanks!
1969 SS 350 Camaro Sold 2008
1970 3/4T K20, stock height with 33's, 250 I6, 3 on the tree, and locked front and rear 4.10's
1980 Chevy Malibu 2 dr Sold 2007
1993 Olds. Cutlass Ciera Wagon Traded 2006
2003 Saturn L200 w/5pd. D/D
My list spans 5 decades with One common thread.....GM!
shelby987 is offline   Reply With Quote
Old 02-06-2006, 06:49 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: wtb: eaton 3rd
well, I have a 4.10 out of a 72 longhorn, it's an open diff though. A dude was supposed to swing by last month to get it, I PM'd him and have heard nothing.
I was gonna get 100 bucks plus ride or pick up locally.
I guess since he is like a month late with no contact... I can sell it if you are interested.
I don't know if you figure 190 miles as fairly close or not... but I'm in Columbus straight south of you.
Old 02-06-2006, 11:02 PM   #3
masterbeavis
Having issues
masterbeavis's Avatar
Re: wtb: eaton 3rd
stick with the 4.57's and buy a detroit locker for a 14B. Buy stock shafts as well for the 14B, stuff it all in, and you are gravy. The 14B stuff will work in an eaton, its been tried, and is true. There was no posi available as far as I know for the eatons, so either you go with a detroit, weld the spider gears (lincoln locker) or stay open.
The detroit fits inside the two piece carrier, so you dont have to pay to have your gears reset. Its a fairly simple locker to install. Check fleabay, they pop-up from time to time, ranging from $300-400. The 14B detroit and shafts are stronger than the eaton detroit btw.
Quando Omni Flunkus Moritati.
The Man's Prayer: "I'm a man, but I can change, if I have to, I guess."
masterbeavis is offline   Reply With Quote
Old 02-08-2006, 11:52 AM   #4
jku72
Re: wtb: eaton 3rd
Originally Posted by masterbeavis
stick There was no posi available as far as I know for the eatons,
My 70 Longhorn has a 4.10 No-spin rear, which is a Detroit locker, as original equipment. It's not for sale, but it means that they are out there.
The 14 bolt stuff fitting in though is very interesting, and if there is documentation or pictures to prove it, then it would be worth buying that stuff rather than search forever for a rare original eaton locker.
jku Cornville, Maine
68 C10 burb
42 Willys MB
46 Dodge WF-32 1.5 ton
53 & 56 Olds'
60 Cadillac
22 Dodge Brothers
jku72 is offline   Reply With Quote
Old 02-08-2006, 02:41 PM   #5
4bynut
4bynut's Avatar
Re: wtb: eaton 3rd
[QUOTE=masterbeavis]The 14B stuff will work in an eaton, its been tried, and is true. There was no posi available as far as I know for the eatons, so either you go with a detroit, weld the spider gears (lincoln locker) or stay open.
Reider Racing now offers a mini spool for the 14 bolt. Starting at $179.95. I'm planning on using one in the eaton for my mud truck. Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 02-09-2006, 01:17 AM   #6
masterbeavis
Having issues
Re: wtb: eaton 3rd
[QUOTE=4bynut]
I stand corrected.
JKU72: No need for pics of the 14B stuff in an eaton. It works, it has been done before many times, its called a hybrid eaton. People dont talk about it here because they dont know about it, are interested in using origonal parts instead of thinking outside the box to make something work, and make it better (for the most part) Some people report that you have to get a 3/8" spacer made for the hubs because the shaft is too long in some instances. One fix involves 5 minutes and a metal cut off saw. If the splines run short, then you need the spacer. I *think* all 14B shafts are the same legnth, but its a good idea to measure what you have before you buy instead of take my word for it.
Old 02-07-2006, 08:36 PM   #7
Longhorn Man
Re: wtb: eaton 3rd
While the upgrades you mention all make sence...why stay with a 4.57 on atruck that sees freeways more than mud?
Old 02-08-2006, 01:37 AM   #8
masterbeavis
Having issues
Re: wtb: eaton 3rd
I assume we are talking about 4WD's here. If not, sell the 4.57's to the 4WD guys. The 4.57's are good for pushing 35-38" tires. 5.14's for 38-40" tires. 4.10's will get the job done with big tires, but your power will be in the upper stratosphere, vs having it in a more useable area for acceleration off the line. For a highway rig, 4.10's make sense for economy, 4.57's on 35's is not too bad on the freeway.
Old 02-08-2006, 12:31 PM   #9
stueber68
1968 C20 Vortec Beast
stueber68's Avatar
Re: wtb: eaton 3rd
Eaton made what was called a "no-spin" 3rd member for the H052 eaton axle. mainly for the 4wd and 1ton. My records indicate that is was only available in 4.11 and 4.56 ratios. This makes it almost impossible to find but it was factory in some.
By the way, my records are the original GM Parts Catalog.
Ugly or not it still kicks a**!
stueber68 is offline   Reply With Quote
Old 02-08-2006, 02:34 PM   #10
Chris H
72 C30 Trailer Queen
Chris H's Avatar
Re: wtb: eaton 3rd
I have a 4.10 center section with the adjustable pinion load deflection bolt, and factory No-Spin (or detroit locker). The unit was factory in a 1972 K20 Super Cheyenne that I once owned. I put about 500 miles on it in 2004 in my 68 C30, but then changed to a 4.10 open.
No one is stepping up with one for sale, so I will offer mine. $400 plus shipping.
You can figure a box 18x18x28 at 149 pounds if you would like to figure out shipping. FedEx ground or DHL are probably the best options, usually something that weight has to go to a business address.
Chris H
72 C30 133"
72 C30 157" flat-dump
69 C10 short fleet
71 ElCamino
2000 K2500 crewcab shortbed (sold, sorry old friend)
2005 GMC 2500HD shortcrew Duramax
2006 K1500 RCSB
and a couple other projects/parts
Chris H is offline   Reply With Quote
Old 02-09-2006, 01:59 AM   #11
Rod
Re: wtb: eaton 3rd
The swaps been discussed here for years... lockers in 14ff to eatons - vice-versa......lots of threads on it in pirate4x4 site also.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 02-09-2006, 03:00 AM   #12
masterbeavis
Having issues
Re: wtb: eaton 3rd
I am just in awe of the general population here wanting origonal parts, and paying SOOOO much for them. i.e. who wants to pay $300 for a set of tow hooks when you can buy the same thing from walmart for $20 a set? $60 and up for a stock set of rear seat brackets.... Heh, who wants to pay $9,999 for a no spin, when you can buy the entire axle with it equpeed with one for less than $4,999 (read that as half the cost(or less) of the no spin), or for the same $9999 buy the 14B one. I dunno, I guess I am just spoiled by the fact that the people I get my parts from think I am doing them a favor by getting the "junk" off of their property.
Shelby: If you were closer, I would trade you straight across my 4.10 for your 4.57 and help you find the upgrades like I mentioned, prolly would be around $400 for the parts to a bullet resistant turnkey axle.
