02-18-2006, 04:43 PM | #1 |
Out of the carpool lane.
Question on making new options sticker with truck modifications
I have the Excel options sticker worksheet and would like to create my own sticker based on the modifications I've done to my truck. Can someone assist me on what factory options list numbers I would want to use along with terminology to make it appear these were factory options? For example: Power disc brakes #43555540 (just a made up number)
Modifications done to my 67 C-10 Carburetor: Weber 32/36 Exhaust manifold: Dual exhaust Transmission: 1970 Saginaw 3speed with 1970 bell housing w/Hurst 3speed shifter Brake power unit: 1977 Chevrolet ¾ T master cylinder/vacuum booster Front brakes: 1977 Chevrolet disk brakes Front wheel spindles: Summit Racing 2-1/2” drop spindle for 1973-1987 Chevrolet pickup Sway bar: Stock heavy duty 1-1/4” Shocks: KYB #KG-5409 front/rear Rear shock relocators: Early Classic Enterprises Original 1967 axle housing with 1970 5-lug axles in it Polyurethane trailing arm bushings Gas tank: 1973 Suburban with filler tube rotated 90* Steering wheel: Grant
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
02-19-2006, 11:35 AM | #2 |
Re: Question on making new options sticker with truck modifications
Brad, Option stickers would have been more like a single letter and two numbers for the codes.
I can see on your list things like Transmission, Power Brakes, Front Disc, Sway Bar, and the Fuel tank that you could probably come up with some numbers for. A V-8 with a 3-spd might be ZW4, 3-spd.manual trans. Power Brakes might be a J70, Power Brakes. F51, Heavy Duty Shocks, Front/Rear F59, Front Stabilizer Then I might try option codes from the later model donors for Larger cap. fuel tank, if so. Things like that. Do you have any of the Resto Packs for your truck or any later models? They could be a big help.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
02-19-2006, 01:36 PM | #3 |
Where can I get the "Excel options sticker worksheet"?
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
02-19-2006, 06:09 PM | #4 |
Living In The Past
http://aplsweb.com/Topics/TopicPix/RPO.pdf Gm option codes. see if this does you any good.
02-19-2006, 07:07 PM | #5 |
8 vehicles only 4 that run
Yukon Jack has a link on his website for the Excel sheet. Find a post of his and his web page link is at the bottom.
95 2500 350 w/ 3.73 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
02-20-2006, 07:37 PM | #6 |
Thanks guys, that'll work!
