10-08-2006, 04:55 PM | #1 |
engine swap, what fuel pump?
i have an '81 k5 4x4, and i have installed a 5.7l fi engine out of a 94 c1500. i am now trying to figure out which way to go for the fuel pump. what year k5 came with fuel injection? i assume they had an in-tank pump. would that be a bolt in swap, or did they change the tanks. any info will be helpful.
67 Chevrolet C10 StepSide 81 Chevrolet Blazer 4WD 82 GMC Jimmy 2WD |
10-08-2006, 06:53 PM | #2 |
junk collector
Re: engine swap, what fuel pump?
87 up k5 had fuel injection. Don't know if tank is different or not, as both mine are FI. The tbi doesn't require that much pressure, so an inline elec pump will work fine if you don't want to put pump in tank.
'87/89/76 K5 in progress '99 K2500 short crew '91 camaro rs '98 jeep tj '52 willys cj3a |
10-09-2006, 08:24 AM | #3 |
Slots go on anything!
The tanks are the same as suburban tanks, those are a lot easter to find around here.
10-09-2006, 10:11 AM | #4 |
junk collector
A k5 tank mounts behind rear axle, a sub has saddle tanks. They are way different. That would be the reason the k5 has has a flat floor and subs have a hump under the seat like a truck.
10-09-2006, 01:44 PM | #5 |
its just $$$$$
10-09-2006, 01:08 PM | #6 |
Only the pickups have saddle tanks.
10-09-2006, 03:58 PM | #7 |
www.73-87chevytrucks.com
Any pump from a TBI motor will work on the sending unit from a '87-up Blazer/Burb.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
10-09-2006, 04:06 PM | #8 |
junk collector
OK, looks like I am wrong on this one. How do some subs have dual tanks? Some do have dual tanks, right? I havn't messed with a sub in a loooong time. I remember pops sub having a 40 gal single tank, so I guess you are right, no way a saddle tank could fit 40 gals. Also no way a 40 gal tank would fit a K5.
I WAS WRONG!
10-10-2006, 07:48 PM | #9 |
so if i have the entire sending unit/pump assembly from the 94 truck, i can use the pump with my blazers sending unit? or will i have to have the sending unit from a fuel injection blazer?
10-10-2006, 06:06 PM | #10 |
Suburban only had rear tanks. 25, 31 or 40 gallon were availible.
10-10-2006, 08:03 PM | #11 |
junk collector
those 2 pumps would be the same, right? The top part that sits on the tankmight be different, but I think they are the same too.
10-11-2006, 03:08 PM | #12 |
I can't say for 100% that the sending unit it the same, I thing it was up to 92, but... The pump will definitely work. I will be using a Corvette pump on mine.
