Old 08-14-2002, 04:39 PM   #1
WB72
Before and After
WB72's Avatar
Question Rear end swap
I'm not sure of the name of the rear end that I have, but it has no access to the gears from the rear of the truck, you get to the gears from the front side. Anyhow, would I be able to swap it for a 10 or 12 bolt unit? A guy I know has a 3.73 12 bolt that came from a 74 C10, he would let me have for $80.00 CAD. Would this be advisable?
My truck is a 72 C20 350/350 with 350 hp.
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 08-15-2002, 10:06 AM   #2
WB72
Before and After
WB72's Avatar
please...
ttt!
66,000 miles.
Alberta, CANADA
Old 08-15-2002, 12:37 PM   #3
palallin
The 12-bolt is a VERY good rear end, but it's a half-ton; you have a 3/4-ton truck. Not only will the wheel bolt patterns not match, you'll loose capacity and ride height. Spring mounts may be different--I don't know--and in different places.
What little I can say without seeing pics/knowing more.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 08-15-2002, 12:51 PM   #4
stllookn
Saving 1 truck at a time!
stllookn's Avatar
If yours has access from the front only it should be a 12 1/4 inch ring gear rear end which is much stronger. I think these came in 7500 lb and 11000 lb capacity. You will not have to worry about breaking it with your typical street engine setup.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
