04-17-2007, 09:52 PM | #1 |
68-72 verses 73 and up front drive shafts
Does any one know if there unversal (interchangable)?
04-17-2007, 10:11 PM | #2 |
Re: 68-72 verses 73 and up front drive shafts
The trucks with the 205s(70-72) and some newer models(73-??) had longer driveshafts than the older ??-69 4wds that had the 221 t case
04-17-2007, 10:38 PM | #3 |
Recovering Truck Driver
I've got to check this one out, I have a front driveshaft from an 87 hanging in the barn, and the u joints are all shot in the 72.....maybe it will fit.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
04-18-2007, 11:33 AM | #4 |
Early model 205's had u bolts to hold the drive shaft to the yoke.
Later model 205's and all the 203's that i saw, had a flat flange to bolt to another flat flange on the TC. I'm not sure about the early Rockwell case's. But they probley had the u bolt design too.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
04-18-2007, 12:36 PM | #5 |
Ol Buck - sorry about your luck, but no interchange...
My Rockwell is U-bolted at both ends IIRC.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current 1969 K20 - V8, 465, 221, Eaton, D44 2012-current Nothin' but drums on all 4 corners! past horses in the stable 72 C10-short step (97-02), 68 C10-long fleet (06-12) |
