06-18-2007, 11:34 AM | #1 |
Licensed to Thrill!
Front Disc Brakes sticking a little - why and how do I fix it?
So I replaced my booster, master cylinder, prop. valve, and lines running to the unions this weekend.
Did a complete bleed until I got clean fluid only through all the lines (from the RR, LR, RF, LF, and brakes stop fine. No light on the dash, everything is really pretty good. Only thing is the fronts stick a little. They aren't just plain grabbing, but they do hold. I jacked up the front, and the wheels won't make a complete full revolution without stopping. The rears are fine. When I started to bleed, I was going to use a vacuum and pull the air out, so I had to start with the LF, and it wasn't going to well, so I went to the old fashioned way (someone pumping, someone opening/closing the bleeder). Well, when we got to the front, it wasn't bleeding good still, actually not all. So after pushing in the pin on the prop. valve and still not getting anything, we figured out the master cylinder had air locked. So we re-bled it (bent lines over into the bowl from the port). It had been bench bled already. Then the fronts bled fine and everything was great. Except the sticking pads. So, that's where I am at. What's to troubleshoot. DLB |
06-18-2007, 11:52 AM | #2 |
Son of a gun
Re: Front Disc Brakes sticking a little - why and how do I fix it?
Did you replace the rubber lines? If not then it could be collapsed on the inside, and acting like a one way check valve, letting fluid in, but not out.
It does not sound like a bleeding problem to me. It must be in the caliper or line.
Bill BEATERS ARE NEATER |
06-18-2007, 12:28 PM | #3 |
did you remove the calipers and clean and lightly lube the surfaces track that the caliper goes in and out on
with no pedal applied the rear shoes retract for no contact of the brake surface and drums/ and the front discs donot retract there is always a slight contact with the pad and disc// as long as the caliper has freedom of movement and the track is not rusted and causing binding you're good to go and will stop just fine
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 06-18-2007 at 12:59 PM. |
06-18-2007, 12:40 PM | #4 |
67-72 Addict!
Just curious, did you mess with the spindle nut at all???. If you were repacking the bearings and overtightened the nut, it will cause a heavy drag when spinning by hand.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
06-18-2007, 01:08 PM | #5 |
Licensed to Thrill!
I didn't go past the unions.
So no spindle nut, and no caliper adjustments or lubing. I am not sure why didn't notice it before though if it were the lines. Perhaps with the prop valve being bad it wasn't holding pressure on it? Thus, letting them bleed back anyhow, even if the rubber lines were bad? DLB Last edited by Orange; 06-18-2007 at 01:08 PM. |
06-18-2007, 03:25 PM | #6 |
There is a differance in disc-drum and drum-drum masters. The drum-drum one have a check valve in the master cly. where the lines screw in to hold about two lbs.of pressure so the brakes shoes will not retract all the way. If you have this kind of master it will not let the disc cly retract enough.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
06-18-2007, 03:38 PM | #7 |
Licensed to Thrill!
This is exactly what I used.
http://cgi.ebay.com/ebaymotors/1955-...38487254QQrdZ1 (You have to do some rod modifying to do it, but it is clean and moves the booster in a ways). DLB Last edited by Orange; 06-18-2007 at 03:39 PM. |
06-19-2007, 07:40 PM | #8 |
This caught my attention. If the rod is too tight it might not be releasing all the way.
How old are the hoses? They could both be bad.
The more I learn about women, the more I love my truck. |
06-21-2007, 01:16 PM | #9 | |
Licensed to Thrill!
Here's the way I set the rod up - I bolted up the booster - fed it thru the firewall, and then connected that to the brake pedal in a strait line without any tension on it. My adjustment can only go in (toward booster), not out (away), because it is already all the way out. So, it is literally as far away as possible. I made the pieces to connect it - instead of using the pieces that were there. I went the hard way around to make sure it was right. The hoses have been on the truck since I have had it (10+ years) so they could be stock for all I know. DLB |
06-21-2007, 06:33 PM | #10 |
We're thinking along the same lines. Something that would affect both front calipers.
Brainstorming here but is there anything that could prevent the rod/linkage from coming all the way back? Hitting the firewall or bracket? Isn't there a rod between the booster and MC? Is it adjustable? Maybe your new booster/MC combo had enough new power to kill both front hoses at the same time? Wouldnt hurt to get some new ones, maybe some shiny steel braided ones, since you dont know how old they are. jhow66 is right. If your hoses are collapsed you can crack the bleeders while they are still stuck. If they release that is a sign pressure is being held there. Again, I'm just thinking out loud so if I'm repeating stuff just put me on ignore, I'm used to it.
06-22-2007, 12:00 AM | #11 | |
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
06-18-2007, 05:19 PM | #12 |
GEARHEAD
Does it pull to one side? If so, it just may be a caliper sticking. It will probably need replacing. If its even on both sides while stopping, I don't know.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
06-18-2007, 06:54 PM | #13 |
Licensed to Thrill!
Not pulling. It didn't have this problem with the old system - but the old system also had a bad booster, bad prop valve (I think) and a leaky master.
DLB |
06-19-2007, 02:40 PM | #14 |
Licensed to Thrill!
Thanks - I'll try that this evening.
DLB |
06-18-2007, 10:18 PM | #15 |
Open a bleeder and see if wheel frees up.
06-19-2007, 08:12 PM | #16 |
Disc brakes??? What are those?
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
06-22-2007, 07:13 AM | #17 |
Licensed to Thrill!
Macky - if that's it, then it's from the union over, and I did it when I put them on (which I really don't think happened, because I pretty much just screwed the new ones on). But if that's the case - then you are going to come over and take the old ones off and put the new ones on for me.
No res. valves in the system. Just the combo/prop valve - and the (what's supposed to be) disc/drum master. DLB Last edited by Orange; 06-22-2007 at 07:14 AM. |
06-22-2007, 09:35 PM | #18 |
I looked at the ad on ebray and they said drum\drum also so there may be residual pressure. One quick way to tell, I think you said you could feel the drag with the wheel jacked up? If so crack the bleeder valve and see if the drag is still there. If not then you have some pressure someplace.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
06-22-2007, 10:00 PM | #19 |
Orange, If you still need some help, I will be around Sunday afternoon. I've got to work and go help my brother Saturday.
cmacky |
