![]() Join Date: Feb 2001
ATTN: Yukon Jack
Ignore the rust and dirt. It is going away
Re: ATTN: Yukon Jack
Any flex when you step up on them?
That's going to be alot of pressure put on the lower portion of the frame rail from the look of it. Do they tie into the vertical part or just the bottom/horizontal area? |
The don't really flex much and they are just bolted to that bottom lip. I dont think there is and down pressure at all on that lip. I would be more like pulling up on it. I am more worried about the two outside bolts. We put some large washers on them but am thinking they probably need some larger plates under the bolts to spread the force out a little more. Had thought about putting some 2" box along the top of that lip and may do it yet. I am just under a time thing right now, this week.
Those are designed to be bolted to the rocker and no way was I gonna do that. Last edited by Mudder; 06-19-2007 at 10:22 AM. |
![]() Join Date: May 2006
Thanks Mudder, my daughter bought me a pair, wasn't sure how to mount them up. That bracket looks like the answer. Is it bolted thru the top of the floor?
She wants to know why they aren't on my Jimmy yet, thinks I don't like them. Couldn't tell her I don't know how to mount them ![]()
![]() Join Date: Feb 2000
Thanks for posting the pics Randy!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
did you make those mounts for those steps?need something like that for my burb.
Me and daughters b/f made them the other night. They are bolted through the floor and used some big washers on the top of the floor to sorta spread the weight out on the floor. Some larger plates would probably be better. To make them really strong another pair of bolts middle wise would be nice also.
Looks really good!
![]() ![]() Last edited by vtblazer; 06-21-2007 at 06:12 AM. |
Thanks, just hope they hold up.
It's totally ok. I think it's good for others to have ideas or concerns when you fab something up. I usually give things pretty much thought before I do it and most of the time it can change a few time while doing it. I would have never mounted it the way the instructions says. I would have been replacing both rockers in no time.
Kid's Mechanic
Mine are mounted to the rockers only and I'm 6' 2" 260 lbs and they don't get any slack from Me
#15 |
Kid's Mechanic
They will might out last the truck if i keep up the mud running
![]() Last edited by powerdriver 1958; 06-21-2007 at 07:51 PM. |
#16 |
Kid's Mechanic
I think a gentleman once told me that his daddy said that was built(hell for stout)
