lowering blocks
how do you install lowering blocks on a 2002 ext.cab 1/2 ton? all the instructions i have read show the leaf springs under the axle but my leafs are on top does that make a difference?
thanks in advance for your help! |
Re: lowering blocks
you can't it will lift it, you need drop shackles (i think they make them) or a flip kit witch will give you about 5" of drop
[PROJECT] FnLow69- 69 C-10 Full frame & layin' doors [PROJECT] Laidout53 - 53' Dodge Pickup, Full Kustom Build [PROJECT] "Hot Rod" 1931 Model A Bonneville style "Dream as if you'll live forever, Live as if you'll die today" ~ James Dean |
Re: lowering blocks
thanks thats what i figured but wanted to make sure before taking them back, and i'll look into the shackles thanks for your help!
Outlandish Trends - FL
Re: lowering blocks
drop shackles will give you 2" drop. You should be able to get them on in about 30-40 minutes. If you want to go lower than this, next step is to get 2" drop hangers (these are the front leaf spring mounts). Little more work to put them on. A flip kit will net you a full 6".
-Bret 67 short-fleet sold! |
