Exhuast headers question
If I install headers on my 283 what will i do about the alternator support thats built into the manifolds?
Re: Exhuast headers question
Most Performance Catalogs Have A Bracket That Works For That Situation . Summit, Jegs, And The Other Companies Sell Them With The Exhaust Kits. Those Headers Will Help That 283 Breath. Good Luck !!
It's A Beautiful Day In Suburbia !!!!! |
![]() Join Date: Nov 2006
you could swap your cyl. heads for the 305 ho heads and upgrade your engine and then have accessorie bolt holes. good swap for a 283
I BELIEVE IN JOHN 3:16 |
I made one from an old stock manifold stud [2" long I think] and two nuts on an Elky once. The two nuts are spun on together right where the mount needs to be. Not sure what your bracket needs to be shaped like, but if it was bolted right to the manifold that should work well for you.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
