10-17-2007, 09:14 AM | #1 |
steering column interchange?
Would a steering column from an '80 4spd 2wd truck work in my '75 4spd 4x4? The wiring the same? Thanks in advance.
-Lance
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
10-17-2007, 09:40 AM | #2 |
Re: steering column interchange?
I'm not sure on your years, I was looking at putting a 75 tilt in a 73 and the wiring looked a little different but the switch that the wiring hooked to was interchangable. good luck.
10-17-2007, 10:34 AM | #3 |
Should work fine.
2003 Silverado K1500 Z71 - Arrival Blue 1973 K5 Cheyenne Blazer 350/TH350/NP203 Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift. RETIRED: 1980 Scottsdale 4x4 Founding Member: "TILT WHEEL BELLY." Club |
10-17-2007, 10:37 AM | #4 |
Robert Olson Transport
i believe that 83 or 84 is when they moved the wipers to the column and thats the change.. im not sure if you could switch off the arms and use the convert columns but there is a bigger hole for the wiper arm than the one with just the turn signal other than that there is no difference between two and four wheel drive columns
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-17-2007, 10:47 AM | #5 |
Awesome,Thanks Guys!
-Lance
10-17-2007, 03:48 PM | #6 |
The 75 column should have a splined end, the 80 should be a double flat on the column shaft. This won't be a problem if you get the mating column coupling shaft. 84 was the first year for wipers on the column.
10-18-2007, 01:05 PM | #7 |
The master of disaster
if you really want to go trick find a tilt and tele colum from an old caddy i believe they came from and pull the wiring piece from youre column and put on that one i did thtwith my 80 that i had and i had more compliments on that then i did when the truck was like new
