Old 10-31-2007, 07:48 PM   #1
michael bustamante
michael bustamante's Avatar
door locks
On my 49 GMC I just noticed that there is only one outside door key lock and that its on the passenger side. how do you lock and unlock the drivers side door? I`m new to these trucks so this strikes me as odd.
1967custom
michael bustamante is offline   Reply With Quote
Old 10-31-2007, 08:54 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: door locks
In that era it was very common to enter and exit on the curb side of the car or truck. They didn't put lock on the driver doors for that reason.
The fix is use a passenger door handle on the other side.
Old 11-01-2007, 03:33 PM   #3
michael bustamante
Re: door locks
my door handles do not have the locks in them I have the lock with the teardrop cover on it. is there any way to lock and unlock the driver door?
1967custom
Old 11-01-2007, 06:35 PM   #4
entourageguy
Yellow truck club
entourageguy's Avatar
Re: door locks
Is it not like the 55-59 p-up's passenger door where you move the inside door handle forward to lock it?
Brian ...
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 11-01-2007, 06:56 PM   #5
michael bustamante
Re: door locks
Originally Posted by entourageguy View Post
Is it not like the 55-59 p-up's passanger door where you move the inside door handle forward to lock it?
Brian ...
you know, I dont know for sure. that makes sense to me but this truck is seein life after 29 years of sitting. I`ll have to play with the inside door handle tonight and find out. It just seemed strnge that the key hole lock was on the passenger door. no way to unlock it from the outside?
1967custom
Old 11-01-2007, 06:58 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: door locks
Locking from the inside was to push the handle in the opposite direction.
Old 11-01-2007, 07:02 PM   #7
michael bustamante
Re: door locks
I bet thats how mine is supposed to be. I`ll be playin with that tonight when I get home. hopefully I wont have to buy a new actuator. ahhhh the good ol` days when life was simpler and you entered the ol pick `em up thru the passenger side
1967custom
Old 11-04-2007, 01:13 PM   #8
Daniel U
Daniel U's Avatar
Re: door locks
I'm pretty sure that's the way to lock it. My '54 is that way. Yeah, "the good 'ol days" you probably didn't have to lock your truck. My truck will have a hidden alarm when I'm finished. I wish, sometimes, I could've been born in the 40's-to learn to drive in my '54 when it was new-and hot rod some muscle cars in my mid 20's. I should be happy to own what I have I suppose. It's the next best thing.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 11-04-2007, 11:22 PM   #9
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: door locks
I did a little research and prior to the mid fifties alot of roads were dirt or gravel. and to keep from getting splashed or your feet covered in mud and dirt you stepped of the side walk onto the running board and into the truck. So it make sense that the lock would be there.
Old 11-20-2007, 10:38 PM   #10
SRA1
SRA1's Avatar
Re: door locks
I've got a 48 chevy pu, same problem. Be careful, if you push the handle forward on the passenger side, it locks out the key. If you do it on both sides and close the doors, you'll be poping a corner window out, it you have one. I speak from experience. Run a screw behind the passenge cross bar to keep from locking yourself out where your key won't help you.
SRA1
Dan Gallagher
dan.gallagher@streetrodadvertising.com
SRA1 is offline   Reply With Quote
Old 11-21-2007, 11:52 AM   #11
michael bustamante
Re: door locks
thanks for the heads up. I`m glad you told me this. I`ll tap that screw in this evening.
1967custom
Old 11-21-2007, 10:13 PM   #12
Lrall
Lrall's Avatar
Re: door locks
i always thought it was because you unlocked the door for your lady and she reached over and opened it for you?? at least thats the good story anyway
Lrall is offline   Reply With Quote
