Old 11-12-2007, 11:32 AM   #1
oldschooler
oldschooler's Avatar
leaking heater core.
o.k. guys. i noticed anti-freeze dripping under hood. It was coming from the heater core. Is this replaced from under the hood or is like the newer vehicles, and comes out from under the dash? It looks like a simple under hood fix, but didnt want to tear into it not knowing for sure. Thanks Guys. Later, Rich
oldschooler is offline   Reply With Quote
Old 11-12-2007, 12:51 PM   #2
71swb4x4
71swb4x4's Avatar
Re: leaking heater core.
It is a pretty simple under the hood fix. I have changed a few, and you can squeak the heater box off with the hood hinge left on, but it's a bit easier if you remove the hood hinge before you pull the heater box.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-12-2007, 12:55 PM   #3
oldschooler
Thanks buddy, I was beginning to wonder if anyone has had a heater core leak before. Thanks again, Rich
Old 11-12-2007, 03:12 PM   #4
48 ish
48 ish's Avatar
I just pulled mine last week. Be careful, there is a screw tab in the lower left hand corner (looking at the firewall) that I couldn't see and ended up breaking it off. Other than that it was easy...
hooberjon@yahoo.com
"Life's Been Good To Me So Far"
1941 Chevy PU (new project, right out of the field)
1948 P/U: 350/700r4, Nova Clip,Chevelle rear, air ride suspension, custom door handles, custom firewall, custom dash, buckets and console, visor
1967 C20: 427 Tall Deck, Turbo 400 with Gear Vendors aux tranny, 5th wheel, 3500 bucket seats and console.
1996 Geo Tracker 2x4
1996 Geo Tracker 4x4
48 ish is offline   Reply With Quote
Old 11-12-2007, 03:23 PM   #5
scotts72heavyhalf
scotts72heavyhalf's Avatar
I have found the best way to replace the heater core is to remove the passenger front tire and inner fenderwell before starting the project, it make getting to all the fastners so much eaiser and the job goes much smoother. its very quick to remove the inner fenderwell and you can also clean up the battery box and other items that might need attention. Also make sure you get the heater core and heater box reseal kit before you start the project, I had to wait a week to get those in the mail and you will have it all apart and you might as well rebuild the box gaskets as its only a $23.00 kit. Good luck its about a two hour job in all.
Scotts72C10
scotts72heavyhalf is offline   Reply With Quote
Old 11-12-2007, 03:45 PM   #6
tk1251k
tk1251k's Avatar
My gmc has air changed a few years back from insidecab Not hard at all.
tk1251k is offline   Reply With Quote
Old 11-12-2007, 08:09 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Originally Posted by scotts72heavyhalf View Post
I have found the best way to replace the heater core is to remove the passenger front tire and inner fenderwell before starting the project...
...Good luck its about a two hour job in all.
The difference here, oldschooler is in the rust belt... sometimes, it can take 30 min just to remove ONE wheel well bolt. Kinda sucks.
No where near the same. A/C truck is a total differant animal.
here is a thread with pics.. step by step;
http://67-72chevytrucks.com/vboard/s...d.php?t=124556
Old 11-12-2007, 09:48 PM   #8
tk1251k
tk1251k's Avatar
Smile Re: leaking heater core.
Mine took about an hour all from inside with a/c. no problem.
Old 11-13-2007, 06:29 AM   #9
oldschooler
You got that right Andy, I dont think I will be taking off the inner fender. In a perfect world, that might be the way to go. My truck pretty much still has all the 35 year old stuff on it. So it is either rusted tight or rusted off.
Old 11-12-2007, 07:00 PM   #10
smoked68
smoked68's Avatar
Changed mine 2 weeks ago,Advance auto,38.00. Not too bad a job, I did break off the bottom left tab though. No biggie I used the black RTV sealer all the way around, bolted back up and it works wonderfully. Nice HOT air for a change. Cleaned out enought leaves to fill the bed of the truck. Good Luck. Mike........
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 11-12-2007, 07:44 PM   #11
oldschooler
Thanks for all the input guys, i appreciate it alot. Thats why I love this site. Later, Rich
Old 11-13-2007, 02:14 PM   #12
Longhorn Man
you can locate the PITA bolt, and then drill a hole in the fenderwell and then put a rubber plug in it. Thats the way they would access spark plugs on some of detroits *tightly packed* offerings.
