turbo enthusiast
just picked up a blazer rear seat to add to my burb as the 3rd seat. Anything I need to know about mounting it for safety reasons or just drill some holes and throw in some grade 8 bolts?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
![]() Join Date: Feb 2005
Re: Adding a 3rd seat
I also would like to hear from someone who has done this since this project is in my near future. I am also installing the narrow 2nd row seat.
'69 3/4 ton 427 CST Pickup '71 CST Blazer '72 GMC 3/4 4x4 |
There should be some holes, or at markings of where they would go, on the floor to mount the brackets.
Do you have all the correct brackets?
you never have too many suburbans.... |
turbo enthusiast
I have the correct brackets but my burb never had a 3rd seat in it before.
Well, I can tell you that the existing rails are either too close to the 2nd row or too close to the back. The gas tank is in the way of inserting a bar/rail for the perfect position. Instead of dropping the tank and going through all that, I just mounted the rear brackets of the bench to the rear most rail. I am assuming you want to mount through some steel and not just the plywood.
![]() Join Date: Jan 2007
If you go through the wood place some wide washers or plate on the bolt head to distribute the load to a wider area.... so as they don't rip through during an accident. Thats essentially how it looks like the factory did it. (Large metal plates with threaded nuts/heads screwed into the wood)
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
turbo enthusiast
I figured I could just drill through the wood and use a piece of flat iron to run the length of the seat underneath to attach all the bolts to.
its all about the +6 inches
Have you done this yet? My assembly manual indicates the holes are there with plugs in the plywood
turbo enthusiast
I have not done this yet. I will have to look for the plugs next time I'm in cali, since that is where the burb is.
![]() Join Date: Apr 2005
Here's some not so good pictures of the bottom. The front of the seat is bolted to the floor with 2 very expensive "c" brackets. They bolt to nutserts that are nailed to the bottom side of the floor. The back of the seat bolts to the metal brace underneath. I believe the seatbelts bolt to the same brace.
R/
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
