Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 01-02-2008, 07:34 PM   #1
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool 73 454 Quadrajet Choke parts wanted
Hi all!
Here is what I am looking for:
I am actually looking for the correct QuadraJet Rochestor 4 barrel carbueretor for my original 1973 Cheyenne Super 454 truck.
I will guess that the GM Carb ID number is alike this:
1703XXXX correct carb # is unkown to me at this time!
What I am also missing is the choke rod, choke heat coil, and choke heat coil cover with screw to the manifold.
The guy who worked on my truck decided I didn't need these parts any more and then realized : WOW ! You need these!
Anyways, if anyone out there has what I need, please let me know!
Do remember that this is the LOW plane intake manifold for a BBC 454 in 1973!
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 01-05-2008, 03:18 PM   #2
PhilaTruck
Right on the line, baby!
PhilaTruck's Avatar
Re: 73 454 Quadrajet Choke parts wanted
There are a thousand different choke set ups out there. You might attach some pix and the numbers will also be necessary to find you what you need.
BTW, you may or may not care, but your 170YYEDT (EmissionsDivisionTransmission) carb is not original to your 73. I know that the 170s are from 76 and on. Here's my source for decoding:
recarbco.com
Not that it necessarily matters for performance, but it sounds like you understandably want to keep the vehicle in original condition.
You might contact these guys for parts, as well:
Carbs unlimited
I've never dealt with them for parts, but have had good experience with rebuild kits. You WILL need the carb number to order from them.
Good luck-
-Todd
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly
Click and scroll down for site vendors!
Subscribe here!
PhilaTruck is offline   Reply With Quote
Old 01-05-2008, 09:23 PM   #3
RPOZ11
RPOZ11's Avatar
Cool Re: 73 454 Quadrajet Choke parts wanted
Thanx!
I did indeed guess at the carb # as I do not know the correct one...YET!
Anyways, I will take a peek at the links you suggested, and yes I do wish to keep this thing stock, regarding the #s and parts..per se.
HO72 build :
2017 SS
