01-14-2008, 06:14 AM | #1 |
core support
can just the rad. and core support be removed instead of whole front clip when pulling eng.and trans.together any help 1984 sub. and 1984 short bed 1/2 ton
01-14-2008, 12:07 PM | #2 |
Parts and more parts
Re: core support
I personally just pull the motor and tranny and leave the core support and that other stuff alone. I see the advantage, BUT I just don't want to take the extra time and deal with it. I can get a motor out in short order and still not hit anything (SO FAR)
01-14-2008, 11:19 PM | #3 |
Robert Olson Transport
Re: core support
you put the truck on ramps or jack it and support it. drop the radiator and remove the tranny support and you dont need to take out anything else to pull a motor and trans together ( except to disconnect the motor and ac and all the other usual stuff
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
01-15-2008, 12:36 AM | #4 |
One shot, one kill.
Re: core support
Dude: Listen to Rusty. you don't have to pull the support, nor do you want to. It's to easy to hurt little stuff like the bumper filler ect and it will take forever to find all the bolts and access them, not to mention the core support body mounts. Pull the hood off,remove the radiator take the cross member out, drop the exhaust as low as you can get it and if it has 4WD and you take the water pump off, you can pull everything in one shot, engine, trans & transfer case. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
01-15-2008, 01:21 AM | #5 |
BAD BOW-Silverado XST
Re: core support
Yes but you will need to at least loosen one fender to get the radiator support out. Don't forget the condensor too. The bolts for the radiator support should be inspected. I had to replace both on my truck. The bolts were nearly rusted through!!! The core support does not drain where the bolts are located.
Take look: One of bolts as soon as I tried to remove it. Last edited by gchemist; 01-15-2008 at 01:22 AM. |
01-15-2008, 05:53 AM | #6 |
Re: core support
It would be easier to pull the whole clip off than to just remove the core support. Trust me, I pulled one from a '73 in a wrecking yard. Luckily, it had no engine and the grille and front bumper was gone. Chevy made sure that the core support was the main structural member of the front group, because there's LOTS of bolts holding it on, and some are in very difficult places.
01-15-2008, 06:02 AM | #7 |
Re: core support
i have both trucks waiting for the swap just looking for fastest way i am taking a 406 from 84 swb and putting it in 84 burb hope i am not wasting motor on the burb
01-15-2008, 06:57 AM | #8 |
Re: core support
i would t hink its fastest to not remove anything but what you have to and you dont have to remove the nose. the time you spend removing the support or the nose would be better spent jacking and easing the motor / trans assembly out.. I did leave taking off the hood which was pointed out by James MC Clure,
Another thing is if the trucks have air conditioning, to remove the nose means you hav to remove the refrigerant and then vacuum the system and install new refrigerant. This can be a pain the butt, particularly if you cant do it yourself whereas you can usually just unbolt the air compressor and lay it to the side or wire it with bailing wire out of the way. I didnt say but you also have to support the tranny after you remove the trans support . I wind up putting a floor jack under it and lowering it so it doesnt slam into the floor Ive done over the years a dozen or so of these kind of swaps, usually with an assistant , and the way ive described is how ive done all of them
