02-25-2008, 01:00 AM | #1 |
Trans-transfercase coupler.
Was wandering if anyone new of an aftermarket part to replace the sleeve between the trans and tcase on a 4speed np205 setup? This seems to be a weak link in an otherwise bulletproof setup.
02-25-2008, 01:55 AM | #2 |
Re: Trans-transfercase coupler.
Did you try the dealership? I thought I had read somewhere you may still be able to get it new.
Aside from that, you have to find a used one, or have one made ($$$). I would just find a later model 32 spline pair instead at that point.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
02-25-2008, 06:51 AM | #3 |
The one I have is not broken, but I know from previous experience this is the first/only thing that seems to break when you put serious amounts of torque through a 4 speed 205 setup. I was wandering if there was an aftermarket part to strengthen this part of the drivetrain.
02-25-2008, 07:29 PM | #4 |
I recently googled "10 spline coupling", because my truck has massive slop when you get on and off of the gas, and found...
http://www.extremegearoffroad.com/st...cat=434&page=1 http://quad4x4.com/GM%20Transfer%20Case.htm Both are $80-85. The one from quad says its made in the USA. Hope this helps.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job" |
02-25-2008, 09:54 PM | #5 |
just bought a new one a few months ago from anaheim gear, very good people to deal with. I think it was like $60
http://www.anaheimgear.com/home.html
1970 K20, 350--- SOLD 05 silverado extended cab short box- duramax Jeep wrangler unlimited |
