Old 10-24-2002, 08:11 PM   #1
Iron-Butt
454 club
Iron-Butt's Avatar
changing to 5 lug axles
Can just change the axles from 6 lug to 5 lug axles without changing the complete rear end?
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 10-24-2002, 08:30 PM   #2
chevy lover
HMMMM Chevy
chevy lover's Avatar
I did without any trouble yet. I found a '72 in the local scrape yard and got the rear. Pulled the axles out and swapped them into the rear of my truck. I would make sure it is the same type of rear, ie. 12 or 10.
chevy lover is offline   Reply With Quote
Old 01-16-2003, 07:35 AM   #3
truckman32
AND HOLDING ON TO THE C10
truckman32's Avatar
at www.stovebolt.com they have some info on this axle change but my advice is to go to a junkyard and match them up if there the same length and the teeth are the same then you got your answer
66 swb/ss chevy c10 SOLD
62 swb/fs chevy c10 :p SOLD
84 swb/fs chevy c10
91 sdime 383/th350
truckman32 is offline   Reply With Quote
Old 04-23-2003, 07:20 PM   #4
jayssunm
jayssunm's Avatar
When you say 10 bolt or 12 bolt what are you refering to? My best guess is the cover bolts.
67 Fleetside Shortie, small window, slip & slide tranny
Upgrades--small block, tilt column, disc 5 lug conversion (front and rear),
Future Projects--suburban gas tank under the bed, rear roll pan, better gas mileage (currently about 6-10 MPG)
jayssunm is offline   Reply With Quote
Old 04-23-2003, 08:01 PM   #5
truckman32
truckman32's Avatar
Donor Rear End Measurements
60-61 inches > 64-69 1/2 ton 2wd Chevy truck/ Some GMC 6 lug rear end 12 bolt Coil spring set up Possible gear ratio's 3.70
62 inches > 64-77 Chevelle, 73-76 Torino, 89 Trans Am,
70 2wd truck 6 lug rear end 12 bolt Possible gear ratio's 3:08, 3:40, 3:73
70-81 4wd 6 lug reared ...............................................................
71- Newer 2wd trucks use a 5 on 5 lug pattern
71-76 Full Size Cars " "" ""
i have heard of the 5 lug axle swap on the 70 they used a 71-?
84 swb/fs chevy c10
91 sdime 383/th350
Old 04-24-2003, 08:09 AM   #6
chevy lover
HMMMM Chevy
3.70 that is what mine is. but I'm looking to find a posi carrier for 4.11's. so if anybody has a 12 bolt carrier I can put 4.11 gears on let me know(as if anybody wants to get rid of them)
68 Chevy C10 swb(under construction)
82 GMC K1500 6.2l diesel (daily driver)
77 Chevy K30 frame (only thing left is axles and trans/transfer)______________________________
Mike
Old 04-24-2003, 07:28 PM   #7
truckman32
truckman32's Avatar
chevy lover.. what year is your truck
84 swb/fs chevy c10
91 sdime 383/th350
Old 04-24-2003, 08:31 PM   #8
chevy lover
HMMMM Chevy
68 chevy 1/2 ton swb
Mike
Old 04-24-2003, 09:05 PM   #9
truckman32
truckman32's Avatar
refering to the axle swap that ironbuttlcmc was asking about on his 63... the swap you did on your 69 truck leads me to believe that your 69 must of had a 6lug 70 model rearend put in it at some time because the 72 axels would of been to long for your 69 rear but the 70"s model rearend is the same lenth as the 72 you purchased at the scrapyard the 72 rearends are 62" long and the 69 should be the same as my 66 60" or 61" the 70's model rearends and the 69 rearends look just a like since they are both 6 lugs just 1 or 2 inches difference i will measure my 66 c10 and let you know for sure,you might want to measure your truck i will ask around here in ky to help ya find them 411 gears ..........i need a 62 truck door
84 swb/fs chevy c10
91 sdime 383/th350
Old 04-24-2003, 09:36 PM   #10
Blue Beard
Blue Beard's Avatar
truckman32
That site has some good information on it..........thanks...........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 04-25-2003, 05:36 PM   #11
Iron-Butt
454 club
Iron-Butt's Avatar
rear end change
I changed out the complete rear end for a 1971 5 lug. I went with a 307 gear since I have been running the 250 6 cyl and 200r overdive tranny. I get great gas mileage and it has great cruising speed on the highway.
David
Old 04-25-2003, 07:07 PM   #12
truckman32
truckman32's Avatar
glad to see you got your 5 lug rearend the way you wanted if i can be of anymore help give me a hollar
84 swb/fs chevy c10
91 sdime 383/th350
