tubes in slicks
I'm running a hoosier qtp 28/14.5/16, and was wondering if you guys know of anybody that sells tubes for this size? I've been all over town here in okc and nobody sells them. I think i can order them from hoosier but don't know what they'll cost.
Re: tubes in slicks
Did you try Carter Maxwell yet (405) 789-8253? They are the local Goodyear Racing dealer. I bought my last two sets of slicks from these guys. Good Luck.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive Interior 1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories My momma took me off the bottle years ago..... |
![]() Join Date: Mar 2008
Re: tubes in slicks
I ran tubes for years and one of the best things I ever did was taking them out . You can rub the inside of the tire with some berrymans tire sealer or do nothing at all . They will lose air but you will never have a tube come apart and ruin a trip to the track . I have opened my trailer the day after a race on more than one occasion to find a flat slick becuase the stem seperated from the tube . On top of all this I picked up about 5 hundreds by getting rid of all that rotating weight .
NHRA Super Street 469C It only runs 10.90 at 156 mph |
Re: tubes in slicks
Regan, can the slicks that i have be patched? I have a small hole about the size of a ball point pen that leaks. Other than that my slicks hold air pretty good.
Re: tubes in slicks
I dont know if that would be dependable or not . I have seen alot of people just put a plug in one to get through the night . You could try a patch and if it failed then put a plug in it till you could do something else .
Re: tubes in slicks
I have been 143mph in my old camaro with a slick with a plug in it! I would try it! You should be fine. I usually use a self vulcanizing plug.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
mini truck racer
Re: tubes in slicks
Not trying to highjack this , but do any of you not run tubes ? I have run truck tubes in mine and had pretty good luck . I now have M/T race tubes . When I tried slicks without tubes I was always messin with tire pressures . Seemed like a hassle . Just looking for input.
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Re: tubes in slicks
Re: tubes in slicks
I run tubeless and I usually coat the inside of the tire with dawn dish washing detergent. Its cheap and helps to seal the tire!
Re: tubes in slicks
I don't run tubes either. I used to use dawn soap to coat the tires...now I tried Green Slime...a thin layer and let dry. So far I havent loss any air pressure in a week.
MT 32x16-15 stiff side walls.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Re: tubes in slicks
Jim did you just wipe it in with your hand like the dawn?
Re: tubes in slicks
I used a sponge.....lol
Re: tubes in slicks
Thanks everyone, I guess i'll try plugging it and coating the inside with that green slime. Hopefully that works. Don't really want to run tubes being they're $60 apiece. Have better place to spend that money.
Re: tubes in slicks
I've never ran any tubes, and have never lost any air pressure at all, even over winter still the same as when I parked it. Hoosier QTP's second set I've had, going to Mickeys this year cause they have the rollout size I want, hope they don't give me any trouble!
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
#15 |
Re: tubes in slicks
it looks like a black catapiller! Not the smooth type!
#16 |
mini truck racer
Re: tubes in slicks
So i'm the only tube guy here ? I still have the 4x4s nailed to 2x4s that slide under the traction bars for storage / air loss . And I keep a pair of valve stems in the tool box incase i have a flat at the track .
#17 |
Re: tubes in slicks
I used to run tubes, but I have had some leaks with them. I think while running 5-6lbs of air in them just wasn't keep them full enuff. They would/could fold. Theres also the added weight(un sprung)
