03-25-2008, 05:38 AM | #1 |
67-72 Addict!
Questions about a 58' Apache
My buddy is looking at a 58' Apache and asked me a few questions about disc brake kits and 5 lug axles for the rear. I'm not very familiar with these years. Where should he get a disc kit and what vehicle can he get the rear 5 lug axles from?. Last question is who sells a patch panel to hide/remove the spare tire indentation?. Thanks!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-25-2008, 05:47 AM | #2 |
Yellow truck club
Re: Questions about a 58' Apache
I've put a 1999 S-10 4x4 4 dr axle works good.
Already had discs on it. Rear fender is best to buy new rather than try to patch. we like pictures.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited Last edited by entourageguy; 03-25-2008 at 05:47 AM. |
03-25-2008, 05:55 AM | #3 |
67-72 Addict!
Thanks Brian, right now he's trying to see if it's worth getting. You are probably right about the fender. Any other options on rear axles for 5 lug? What about front disc kit?.
03-25-2008, 06:26 AM | #4 |
Yellow truck club
A quick look on CPP web site found this.
http://www.classicperform.com/Store/...s/4759DBK5.htm others will chime in on your question.
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
03-25-2008, 06:30 AM | #5 |
if that truck is a short wheel base, i would love to have that rear fender and the brackets to mount the spare tire on the side! i would trade my fender for those if what he has is in good shape. OR, i just happen to have the brackets and parts to switch to front disc brakes and also add power steering, if he might be interested. i just put trans am clip under mine so i dont need those parts.
can give me an email to hotrodsbyray@yahoo.com if he would like to do any swapping - same goes for any body else that has a good spare tire fender and brackets for a short step side. also have good original front axle with springs and brackets if that would sweeten the deal or if anybody needs them. |
03-25-2008, 08:09 PM | #6 |
67-72 Addict!
Thanks again Brian!
hotrodsbyray- He doesn't own the truck yet will give him your info in case he gets it. Thanks
04-04-2008, 05:13 AM | #7 |
I purchased the conversion bracket kit from CPP on this link http://www.classicperform.com/4754chevtrk.html 4759DBK5 5-Lug on 4-3/4" Bolt Pattern Disc Brake Bracket, kit. Cost around $105 shipped, and use rotors and calipers off one of my 74 El Camino parts cars, they bolted right up to it. I did put new bearings and seals in the rotors....
04-04-2008, 04:48 PM | #8 |
There was an article in Classic Trucks a few months back where they were using the 10-bolt posi rear out of an 81 Trans Am. Supposedly it was the same width as stock but with discs.
04-04-2008, 06:22 PM | #9 |
polishing a turd
it should be.
i am using a 77 nova 8.5" 10 bolt rear with 12" discs from a 98-02 f-body. the brakes bolt right up, just switch the brackets side to side (put the right on the left, and left on the right) and only cost $200 on ebay.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512 53 buick special - straight 8 sled - blow through turbo 47 gmc - flatbed hot rod build 99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van' |
