Old 04-01-2008, 11:20 PM   #1
Mister laugh
Fuel Strainer
Can i run without a fuel strainer, and an inline filter in front of the pump, as well as in front of the carb? None of my local dealers want to order me one and i want to get my truck back on the road.
Matt
Mister laugh is offline   Reply With Quote
Old 04-01-2008, 11:23 PM   #2
ed2552
ed2552's Avatar
Re: Fuel Strainer
go to NAPA or whatever and get a cheap filter and put it front of the carb. You are asking for trouble by running w/o a filter.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 04-01-2008, 11:26 PM   #3
Mister laugh
Re: Fuel Strainer
I never said anything about running without a filter............. I asked whether the strainer is necessary or if it could be SUBSTITUTED with an extra inline filter.
Old 04-01-2008, 11:32 PM   #4
ed2552
ed2552's Avatar
Re: Fuel Strainer
Old 04-01-2008, 11:32 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Fuel Strainer
I never run the strainer, and you should never run a filter before the pump. The more dirt that gets in the filter, the more it reduces the pressure in the line as opposed to atmospheric pressure, and this can cause, or agravate a vapor lock condition.
Old 04-01-2008, 11:36 PM   #6
Mister laugh
Re: Fuel Strainer
Thanks for the quick answer, so it's ok if all the dirt and rust and 40 years of other crap that is in the tank goes through the pump? I just figured it was bad for that stuff to hit the pump.
Old 04-02-2008, 12:30 AM   #7
Longhorn Man
Re: Fuel Strainer
if you have the mechanical pump, then yeah it's fine. If electric... then no.
I doubt you have a WHOLE LOTTA CRAP in there... you'd probably be stressin if you looked in there and it was real bad.
