Old 10-30-2002, 04:58 PM   #1
78SilveradoSWB
78SilveradoSWB's Avatar
Lowering Blocks
Any pro's or con's in using a lowering block in conjunction with a flip kit to lower rear to 6"?
78SilveradoSWB is offline   Reply With Quote
Old 10-30-2002, 06:15 PM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
I would not recommend using blocks! Just install 2" adjustable shackles and set them at the 1" setting.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 10-31-2002, 02:58 AM   #3
78SilveradoSWB
LowC10 (Dave)
If I use the lowering shackle, will I then have a problem in using a air lift air bag?
Old 11-01-2002, 04:29 AM   #4
78SilveradoSWB
ttt
Old 11-01-2002, 06:13 PM   #5
Tom
driving is in my blood
Tom's Avatar
There is absolutly no problem using lowering blocks. Heck, thats the only reason Im going with a flip kit is so if I ever want lower all I need is blocks. Shackles require cutting bed supports, hangers require grinding off old rivits. Big pain in the butt.
Old 11-02-2002, 12:39 AM   #6
BaggedC10
Under construction!
BaggedC10's Avatar
Originally posted by 78SilveradoSWB
LowC10 (Dave)If I use the lowering shackle, will I then have a problem in using a air lift air bag?
Nope!
Old 11-02-2002, 12:40 AM   #7
BaggedC10
Under construction!
BaggedC10's Avatar
The proper tools make the job 100% easier!
