Old 05-08-2008, 03:19 AM   #1
dkauffman05
dkauffman05's Avatar
Is new panhard bar needed ?
I have just aquired a 72 swb . I would like to drop it 4-6 but from what i have been researching the kits come with new panhard bars , shock relocators. my ? is can i get that low without spending upwars of $700.00 foe a kit or can i get spindalls and some rear springs and or blocks to get the drop i want? i am probbly gonna be running a 15x8 ralley with 255- 60 or 275-60. thanks.
dkauffman05 is offline   Reply With Quote
Old 05-08-2008, 03:43 AM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Is new panhard bar needed ?
I might be wrong, but I believe your rear end will be out of alignment with out it. I'm planning on running a 4.5/6 ECE drop kit with their super track bar. I'll let some other chime in on this.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-08-2008, 05:00 AM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
If you have any fab skills, its not hard to mod your stock pan hard bar
& for a 4" drop up front, its not much different to just cut one round off your coils with a cut off wheel & get about 3" drop (some do more that a round, but I dont know what problems you might run into)
Then in the back just take a torch & heat the springs up & measure as you go, so you get them level side to side & the amount of drop desired
Then take your pan hard bar loose & center it on your frame, then cut it in half & get a piece of pipe that fits over it (basically as tight as possible) then measure how long it needs to be with your axle centered & weld it up
Boom, free drop
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 05-08-2008, 05:55 AM   #4
SCOTI
SCOTI's Avatar
Since it's a 72 & already has disc brakes, get some drop spindles for the front & cut 1-coil.
For the rear, if you have the coil suspension hit your local steel yard for some 2" square .250 wall tubing & make your own lowering blocks..... http://67-72chevytrucks.com/vboard/s...d.php?t=196457. Cut the tubing to length, drill the holes, & then pick up some 2" longer u-bolts (local spring shop or board vendor for about $40). Add some 4" drop springs & get an adjustable panhard bar or shorten the stocker. You can modify the stock shock brackets to function just like the aftermarket $80 relocator kits or splurge on some 'drop' shocks.
If you have leaf springs, do a flip kit & you're done...... http://67-72chevytrucks.com/vboard/s...d.php?t=223158 . Pay close attention around pg.13/post #309.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
