Old 05-16-2008, 09:41 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Filling trim holes around rear taillights
I did search several different searches but found no answers
I am planning on biting the bullet and getting Musclerod's rear lights/bezels. This will require me to fill in the holes for the factory trim. I am having help on the bodywork and want to make sure we do it right. Will it be okay to simply fill the holes with body filler or is there a better way to do it? Thanks!!!
Old 05-16-2008, 12:08 PM   #2
JimKshortstep4x4
Re: Filling trim holes around rear taillights
If it were mine, I would weld the holes to fill them in.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 05-16-2008, 02:46 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
Well, i've never welded, but the guy doing the body work is using a wire feed welder. WIll that work okay or warp the metal? Do i just make sure he goes slow and switches sides? Since the holes are so small do we need small patch pieces or just fill w/ the wire? He's done a great job with the other patches, but they were full panels like rockers and cab corners. Just want to make sure the new (old but new to me) bed isn't boogered up. Sorry, noob here....
Old 05-16-2008, 02:53 PM   #4
Madmandav
Madmandav
Madmandav's Avatar
No patches will be needed, just take it slow do a little at a time and it will be fine.
I must be crazy, that's what the voices in my head keep telling me.
Project FROSTBITE
http://www.67-72chevytrucks.com/vboa...d.php?t=280249
http://www.67-72chevytrucks.com/vboa...d.php?t=287407
'72 Chevy longbed
'70 Chevy longbed (million pieces)(FROSTBITE)
'79 Monte Carlo
'07 Chevy HHR
'00 Yamaha V-star
'05 Monte Carlo SS Supercharged
Madmandav is offline   Reply With Quote
Old 05-16-2008, 03:09 PM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
Weld the holes is the best way and the most permanent. Use a small piece of metal or a short flat head screw as a backing plate and use the wire feed welder to spot the weld in. Hit the spot with the welder and back away to allow for cooling, then fill the weld as necessary. Using a grinding tool with a flapper wheel or a 3-m nylock pad to smooth and prep for body filler. Ensure that you try to cover the spot on the backside with a good paint or weld primer.
Old 05-16-2008, 04:46 PM   #6
Charlesdur
Charlesdur's Avatar
agree... don't use bondo to fill these holes. There is a very good chance that it will pop or show a small defect in the paint over time.
Charles
1971 3/4 ton
454 cu.in.
4 speed manual
1966 Thunderbird
390 cu.in.
Airride
Roadster
Charlesdur is offline   Reply With Quote
Old 05-16-2008, 04:50 PM   #7
sleepyboy
'69 Step
Weld
It's my truck, and Yes, I CUT the dash, so what??
sleepyboy is offline   Reply With Quote
Old 05-16-2008, 04:58 PM   #8
Charlesdur
Charlesdur's Avatar
post pics also. I am doing the same thing on my truck and did some previous research.
Charles
1971 3/4 ton
454 cu.in.
4 speed manual
1966 Thunderbird
390 cu.in.
Airride
Roadster
Old 05-17-2008, 07:02 AM   #9
VA72C10
VA72C10
VA72C10's Avatar
Thanks everyone....i'll post up pics on my build thread when i get to start working on the truck again.
Old 05-17-2008, 07:35 AM   #10
cstm68
cstm68's Avatar
there is a pic i my build thread of how i welded them on my truck.
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
