Old 05-17-2008, 07:58 PM   #1
Jtrux
I'm a poor spectator
Jtrux's Avatar
Well I know what my first body project is going to be...
I picked up a Miller 175 so now the work can begin. I don't want to jump right in to floors and rockers so i'm gonna start with something less critical. I'm gonna pick up the patch panel from GMC Pauls for the area under the battery box on the front of the passenger fender. Mine looks solid but is actually just bondoed up so it'll be replaced soon. I just need to get Critter over to my house to put in a 220 plug in my garage since he's an electrician and all.
You can see the discoloration of the lower body where they bondoed and half ass painted it.
I probably have my work cut out for me by the time it's all said and done cuz I even found some bondo on one of the bedsides so who knows what's under that.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 05-17-2008, 09:31 PM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Well I know what my first body project is going to be...
I know, I know...rust and dents! Did I win anything?
hgs_notes is offline   Reply With Quote
Old 05-17-2008, 09:33 PM   #3
Jtrux
Jtrux's Avatar
Well no prizes to give out yet. I did sand a few areas down and found mostly dents but some rust too. So I guess i've got it all. I also assumed my welder had .030 wire but it's actually .023 which I guess is better for body work. Now I just need to do the work.
Old 05-17-2008, 09:37 PM   #4
watahyahknow
watahyahknow's Avatar
dunno if you know but when welding to the car take the batterycable off so the regulatorthingie doesnt go poof
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-17-2008, 09:52 PM   #5
Jtrux
Jtrux's Avatar
Yes sir but thank you anyways, i'm sure someone will read it and go "OH!!!". For my fender project I do plan on having the fender off so it won't be an issue.
Old 05-17-2008, 11:42 PM   #6
Big J
Its lookin' like a Blazer!
Big J's Avatar
Are you using gas? If not ya might wanna take a look at doing so. Makes a much cleaner weld. Yes the .23 is much better for thin stuff. I used what I had left of the .30 on the floor pans but .23 would've been easier to use. On the 220 your having put in, see if ya can't have it set up about 25 or so feet of wire so ya can reach out in your driveway. Makes it handy.
BAZINGA!
My Build
Big J is offline   Reply With Quote
Old 05-18-2008, 12:55 AM   #7
Jtrux
Jtrux's Avatar
Yes i'm using gas. I'm gonna make an extra cord that's longer for when I need to drag it around but just leave it next to the outlet and make a small table with a vise mounted for doing small welding projects.
Old 05-18-2008, 06:11 PM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Koool keep us posted on the progress...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-19-2008, 07:50 PM   #9
Critter
Future TOTM Winner
Critter's Avatar
So when are you going to bring it by my place for a test run?
J/K We will get you fixed up with an outlet in a day or two. I can't wait to tear into yours and see what all we can screw up...I mean "fix"
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
