Old 06-10-2008, 11:27 PM   #1
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
6 lug rotors?
I want to keep the burban on 6 luggars when I lower it, anyone know what 6 lug rotors came on or where to find some? I am going to use 2.5 drop spindles and 3" drop coils. also looking for a brake booster if anyone knows where to find one that fits our trucks. I cant afford the aftermarket kit, $900 for brakes is to much for a truck that already stops good.
kdrodworks316 is offline   Reply With Quote
Old 06-10-2008, 11:40 PM   #2
62 short step
62 short step's Avatar
Re: 6 lug rotors?
Classic Parts, CPP.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 06-10-2008, 11:43 PM   #3
LILRED66
LILRED66's Avatar
Re: 6 lug rotors?
Are you looking for a factory power brake booster and mounting wedge? If so, post an ad in the parts for sale forum.
LILRED66 is offline   Reply With Quote
Old 06-11-2008, 10:03 AM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
Re: 6 lug rotors?
Here: http://www.truckandcarshop.com/trucks60_72/t60_115.html $75 each..
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 07-02-2008, 11:19 PM   #5
joe231
joe231's Avatar
Re: 6 lug rotors?
Originally Posted by Chevy Fleetside View Post
which spindles do those fit???
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-03-2008, 12:01 AM   #6
Chevy Fleetside
Re: 6 lug rotors?
I am going to guess and say 70's spindles.. I would call the truck and car shop and ask them. CCP if they are cheaper...
Old 06-15-2008, 01:57 AM   #7
soba_03
soba_03's Avatar
Re: 6 lug rotors?
KD,
Check out D&R classics it's the palce that I bought my drilled and slotted rotors. They are not your mainstream truck parts place. However I know that they had 6 lug and 5.5 lug when I bought mine. I have to say DAM they are nice and not cheap repo's.
I paid 168 for mine drilled and 5x5.5 but might be worth a look...
Regards.. Heres a pic, I know that this is 5.5 but give you and idea how nice they are....
soba_03 is offline   Reply With Quote
Old 06-15-2008, 06:09 PM   #8
joe231
joe231's Avatar
Re: 6 lug rotors?
soba,
$168 each??
CHEVY ONLY
Old 06-15-2008, 07:10 PM   #9
MickMc
MickMc's Avatar
Re: 6 lug rotors?
1990 heavy half 6 lug rotors
Delco # 18A955
Mick
MickMc is offline   Reply With Quote
Old 06-15-2008, 09:03 PM   #10
joe231
joe231's Avatar
Re: 6 lug rotors?
Delco # 18A955
Mick
I have heard they don't work with the older spindles, offset is wrong
CHEVY ONLY
Old 06-15-2008, 09:10 PM   #11
soba_03
soba_03's Avatar
Re: 6 lug rotors?
No that was for the set.... May seem a little high to some but I thought it was a good price for what I got...
Old 06-15-2008, 09:22 PM   #12
MickMc
MickMc's Avatar
Re: 6 lug rotors?
Yes, you do need the 88-9? spindles and 3/4 lower ball joints and 88 upper ball joints.
The 88-9? spindles are a dime a dozen and good priced too. Aftermarket lift or lowered.
The rotors are cheap and the calipers are about the same price.
At least I don't feel like I'm being abused for owning a 67 truck, by buying the later model common parts.
I'm collecting the parts to convert mine right now (that's why I have the rotor part numbers in front of me)
Mick
Old 06-17-2008, 08:23 AM   #13
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: 6 lug rotors?
Mick
My research found that for this conversion your need 3/4 ton lower A-ARMS to be able to press in 88-98 1/2 ton ball joints (the 3/4 ton lowers use the same diameter press in size as the 1/2)
So your say a 3/4 ton 88-98 ball joint will press into our old a-arms ?
And is needed for the 1/2 ton lift/lower spindle ??
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 06-17-2008, 11:11 AM   #14
MickMc
MickMc's Avatar
Re: 6 lug rotors?
I am checking on the lower A-Arm ...I have a pair of 3/4 lowers in storage and I will grab a pair of calipers and do some checking. I would hate to have to sell my brand new tubular lowers...
If the lower mounting cup is different then yes you would need 3/4 lower arms (I saw a bunch at the U-Pull It yard a couple of weeks ago)
The upper arms, the ball joint just bolts in, no problem there
Mick
Old 06-22-2008, 03:36 AM   #15
Captainfab
60-66 Nut
Re: 6 lug rotors?
Mick
I'm collecting parts for this conversion also.....yes you do need to use 3/4 ton lower a-arms (the '67-'72's have a lower bumpstop mount). I'm contemplating doing a little surgery on some '73-'87 1/2 ton lowers so I can use them since I like those bushings better. For more info on this swap HERE is the thread in the FAQ's. I can help with part numbers if anyone needs help finding the parts.
Old 06-15-2008, 09:47 PM   #16
joe231
joe231's Avatar
Re: 6 lug rotors?
not bad for some nice rotors, imo
is this the place?
http://www.drclassic.com/index.html
all i see is Camaro and Chevelle stuff?
oh and by the way....why 5 on 5.5?
CHEVY ONLY
Old 06-15-2008, 09:45 PM   #17
joe231
joe231's Avatar
Re: 6 lug rotors?
the light 3/4 ton rotors i have looked at are $80-$90 range, not what i would call cheap, but maybe that's because i am
CHEVY ONLY
Old 06-15-2008, 10:58 PM   #18
kdrodworks316
KOFFIN DRAGGER
Re: 6 lug rotors?
I found a pair a cpp for a $125, I think I will go that way.
Old 06-16-2008, 03:04 AM   #19
soba_03
soba_03's Avatar
Re: 6 lug rotors?
Joe,
That is the place, just call them Trust me the specialize in 55,6,7 chevy and camaro's and nova's But they have truck stuff too...Not like our vendors of course but they beat all the prices I could find for drilled and slotted. Yes 5 x 5.5 these are truck rotors.....
Old 06-16-2008, 08:19 AM   #20
joe231
joe231's Avatar
Re: 6 lug rotors?
thanks Soba
I'm confused why you are running 5 on 5.5, Chevy truck pattern is 5 on 5, or 6 on 5.5.
Dodge, Ford, Jeep, and IH are the ones I know of who have 5 on 5.5
CHEVY ONLY
Old 06-16-2008, 10:26 AM   #21
Chevy Fleetside
Re: 6 lug rotors?
If you use a mid 70's frontend set up and convert to 5 lug, you can get rotors for these prices.. http://www.partsamerica.com/ProductL...pe=221&PTSet=A
Old 06-16-2008, 11:26 AM   #22
soba_03
soba_03's Avatar
Re: 6 lug rotors?
Your right i'm a dumb A$$ these are 5 on 5 the 6 lug i removed are 6x5.5. This is the truck pattern 5x5.
Old 06-17-2008, 12:15 AM   #23
joe231
joe231's Avatar
Re: 6 lug rotors?
gotcha, thanks
CHEVY ONLY
Old 06-17-2008, 11:00 PM   #24
kdrodworks316
KOFFIN DRAGGER
Re: 6 lug rotors?
I have decided on the CPP rotors, mainly because a fellow board member, suicide_63, hooked me up with a swingin deal! I love this board!
Old 07-03-2008, 12:22 AM   #25
joe231
joe231's Avatar
Re: 6 lug rotors?
thanks
CHEVY ONLY
