Old 06-17-2008, 11:11 AM   #1
MickMc
MickMc's Avatar
Re: 6 lug rotors?
Originally Posted by ChiefRocka View Post
My research found that for this conversion your need 3/4 ton lower A-ARMS to be able to press in 88-98 1/2 ton ball joints (the 3/4 ton lowers use the same diameter press in size as the 1/2)
So your say a 3/4 ton 88-98 ball joint will press into our old a-arms ?
And is needed for the 1/2 ton lift/lower spindle ??
I am checking on the lower A-Arm ...I have a pair of 3/4 lowers in storage and I will grab a pair of calipers and do some checking. I would hate to have to sell my brand new tubular lowers...
If the lower mounting cup is different then yes you would need 3/4 lower arms (I saw a bunch at the U-Pull It yard a couple of weeks ago)
The upper arms, the ball joint just bolts in, no problem there
Mick
MickMc is offline   Reply With Quote
Old 06-22-2008, 03:36 AM   #2
Captainfab
60-66 Nut
Re: 6 lug rotors?
Mick
I'm collecting parts for this conversion also.....yes you do need to use 3/4 ton lower a-arms (the '67-'72's have a lower bumpstop mount). I'm contemplating doing a little surgery on some '73-'87 1/2 ton lowers so I can use them since I like those bushings better. For more info on this swap HERE is the thread in the FAQ's. I can help with part numbers if anyone needs help finding the parts.
