Like a Rock!
Rear shock relocators- How hard to install?
I thought there was a FAQ on installing these but I can't find it. If anyone has done this, was it a pain to grind the rivets off? Seems like it would be tuff to get the grinder up in there. Is CPP's kit the same as ECE's kit?
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
Re: Rear shock relocators- How hard to install?
it sure is alot easier to do bedless//if you have a compact enough grinder the thing that makes it bad with the bed on is the grinnding residue seems to come right back at you// my favorite grinder nowadays is my 3"airpowered cutoff wheel
Like a Rock!
I plan to do this with the bed on. Unfortunately I'll be on the ground!
![]() Join Date: Apr 2005
I can't speak for CPP's, but I've installed ECE's on my two trucks and am very happy with fit and quality. Invest in an air chisel, it will make the job much easier... Here's some pictures of my crewcab with them installed....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 07-20-2008 at 10:34 PM. |
I used ECE's kit. It was easy and fit was not an issue at all. I also had the bed off for grinding the rivets.
1970 C10 - ECE 3.5/5 drop, dual exhaust with turbo mufflers, front discs http://67-72chevytrucks.com/vboard/s...d.php?t=272458 2000 Buick Regal GS - Supercharged 3.8 V6 240hp, 1/4 mile 15 seconds |
i just put 5 inch drop spring on my truck and it still sits up high in the back.i didnt change the pan hard bar nor did i use the shock relocators.do you guys think thats the reason why me truck still sit kind of high in the back???
Like a Rock!
Thanks or the pics Rob.
If you try to push down on the back or bounce will it go down or are the shocks bottoming out?
No more dragtruck for me. I'm building a new ride though. It's a '71 fleetside, 400 sbc, 700R4. Working on it now, finally. Soon to have Edelbrock Pro Flo EFI, Vintage Air, 1 piece windows, buddy buckets, etc. My new build thread: http://67-72chevytrucks.com/vboard/s...17#post2861817 Best pass with the old dragtruck: 5.32 @ 131.6 mph 1/8 mile w/ a 1.25 60' Fogger/Plate 2003 Best pass with the street 406 hydraulic roller motor w/ mild plate tuneup 5.93 @ 114 mph 1/8 mile w/ a 1.29 60' 2003 or 2004 |
#9 | |
Retired Air Force Veteran
![]() Join Date: Aug 2007
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop ![]() Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
i had some boys come over and take the bed off real quick to grind the top rivits. the bottom nuts can be a *****. i got mine from cpp, the angle of the bottom brackets were off where the shock mounts. it wasn't flush, but i put a bolt through the hole/shock anyways even though the angle's off a little.
Loving the Jimmster
Ok silly question, but why do you need ot relocate the rear shocks??
Damn Yankee
Like a Rock!
Thanks for all the responses. I was hoping to hear from somebody who did this the bed on!
#14 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#15 |
Damn Yankee
It will be a LOT easier to install with the bed off. I've been taking the rivets out by grinding the top flat (just a little bit so your drill bit doesn't wander- could do the same thing with a punch) and then drilling a pilot hole with an 1/8" drill bit, then drill with a 3/8" bit...one quick blow with a chisel and they pop right out.
This just saves you from grinding the frame itself AND I've totally ground a head off and not been able to get the rivet out....with the drilling it works quick and easy. The kit fits great and went in pretty painlessly |
#16 |
Engine n00b
1 hour per rivet if you have ****ty tools.
#17 |
Tasty Cakes!
I agree, if you have room, take the bed off. You will save time and will be less likely to get hot metal down your collar.
I'm a little ![]() ![]() Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
#18 |
Rob has the best advice..... zip gun/air chisel and use ECE stuff.
sure made the job easier for us.
#19 |
I recently installed the ECE kit with the bed on. I followed the angle grinder / air hammer technique:
http://67-72chevytrucks.com/vboard/s...d.php?t=291939 It was a little tricky getting the angle grinder in there to grind the rivet heads, but if a rookie like me can do it, I'm sure you can. The air hammer was crucial, though. I borrowed my neighbor's Snap-On and it worked great. |
