home made S10 body mounts?
Who has made thier own S10 body mounts? I have NO welding skills so i'd have to take the plans to a welder/machinist to get them done. I heard getting a set made is a lot cheaper than the kit. I'm curious who has made thier own or had some made and used them.
Re: home made S10 body mounts?
i did mine using jeffs plans but used square tubing. if you cant weld you could just drill and bolt through. i believe the thread is "not another s10 swap".
this worked out pretty good, or you can cut tubing 4x4 tubing.just use themeasurments off the pic
you may want to lower the mounts even the designer lowered them after looking at how high it sat. i dropped mine using a 2x4 plus the rubber mounts. just decide where you want the body heighth.
i also lowered mine 2" above the frame and used the s10 rubber
Swifty, the mounts are easily made using tubing or bent flat stock. If you need pics of the mounts themselves or have questions, just let me know. The question you need to ask is, "how much modification do you want to do?" The higher you go, the less changes you need to make. If you go six inches or more, everything rides on "top" of the frame and you don't have to cut much. I was there once and it worked ok. In my opinion, for the amount of work this swap takes, I have decided to go lower. Currently my front mounts are 3 1/2 inches plus the s10 cab bushing. The rear mounts are 4 plus the bushings. If you haven't checked out my thread, you can see it at http://67-72chevytrucks.com/vboard/s...d.php?t=294539. If you have any questions, I will try to help out as much as I can.
Thanks, Jeff |
thanks for the replys! if you don't mind can you post pics of the mounts installed w/out the cab? I like the look of 2" above the frame but what cutten/mods is needed?
I originally was going to use the s10 swap kit that can be purchased but i kinda need to budget this build now, but i think we all know how that goes. Thanks again guys! this is my first frame off build and i'm pretty new at all of this so i'm sure i'll have a TON of questions as the build progresses. Last edited by Swifty; 10-24-2008 at 02:57 AM. |
i have a 58' that somebody put on a later chevy pickup frame (67'-70) and they just used round tubing. the mounts are easy as you just need some wood to get your spacing and transfer to metal.
Be careful How much you lower the cab, it will affect other items such as the clearance between your trans tunnel and cab. This area would have to be modified/cut. I have found the optimum clearance between the distributer and stock firewall to be about an inch. In this position I have about a 1/2 inch clearance between my trans and cab. I fabricated 3/8's plates and bolted those to the frame, then fabricated mounts that placed the engine mount bolts about an inch above the plates. (Hope this doesn't sound too confusing)
The reason I mention this is because there is very little room to play in mounting the eng for and aft especially if you want to run a mechanical fan. I don't know how high my cab is sitting in relation to my frame I would have to measure but 10.25 sounds about right. Last edited by 51chevytruck; 10-24-2008 at 11:35 AM. Reason: spell ck |
i just used 2x3 tube. bolted it to the frame. pics in my post.. (s10 swap...yea another one)
I used the stock rear s10 mounts for the front AD mounts. The rear still uses the stock AD shackle
I know this thread is a little old, but I had my cab off. Here are some pics:
Front ![]() Rear ![]() Hope it helps |
thank you for the follow up. the pics really do help!
Has anyone used these mounts for an AD Suburban. I am wondering if they're the same? I am compiling parts for my tear-down and rebuild.
#15 |
![]() Join Date: May 2013
thread is 8 years old , check the sticky up top on s10 swap , by skymags
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
#16 |
Any pics on how you did the mounts for the bed and back rear. And how you did the front end mount
Thanks Juan Frias |
#17 |
![]() Join Date: Aug 2015
