Bearing Race Removal
How do you remove the bearing race from a rotor? is it machined out or pressed out?
Re: Bearing Race Removal
wipe the rotor out...you see an indent in the rotor where you can put a punch or the back lip of the race...from the opposite side hold the punch in the indent and hit with a ball peen or mallet hammer...after you feel it move some...go to opposite side of race and look for lip...place punch on lip and drive it on out...or old school...heat with a torch till red and turn it over and watch it fall out...good luck
i've always just used a chisel punch or screwdriver wichever i grab first to knock it out from the rear//never had a problem doing it that way
ok cool. i wasn't sure if it was that easy.
thanks |
I am a Referee of life.
Make sure you use a Brass punch or wood when reinstalling.You don't want to use anything that might mar the new race.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Another trick to get the new ones in is to place the old race on top of the new race and tap on the old race till the new race is in.
X2
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
Gone to greener pastures
![]() Join Date: May 2007
Use the old race "backwards", so you have a "lip" for driving the old race out.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
Refrigerate(put the new one in the freezer for about an hour) and it should almost drop in.
Watch out for your cornhole !
![]() Join Date: Jun 2003
I take my welder and run a bead inside the bearing race. It will shrink and fall out when it cools.
Rods
![]() Join Date: Nov 2002
hmm thats a new one.. I have heated the outer surface. but the welding thing sounds like it would work.
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
yea but by the time you weld the bead you could have already just used a punch and knocked it out. Its not that hard. Just sayin ... cool idea though.
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
great info.
i have the ECE drop spindles and disks. do they use the stock bearing or do i need different ones? |
ECE rotors and spindles use stock bearings and seals for 71-87 HD truck rotors.
#15 | |
Sure, here. But some other applications have blind areas where races can't be pressed out (ie Harley XL steering head bearings) and that's a good method to have in your head. I like to be the go-to guy in a shop for difficult problems.
