New Wheels?
Can anyone tell me if a 22"x9.5" with a 5.25" backspacing work all the way around a 67'? It is 5 lug with a 4/6 drop?
Still livin the "dream" in '54
Re: New Wheels?
Welcome to the site. I am sure someone will chime in with the answer you are looking for!
Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
Tot Roddin'
Re: New Wheels?
First off
![]() Secondly, when it comes to wheel choice and BS selection, it is best to stop by your local (reputable) wheel/tire shop and have them help measure the correct BS. Even though a truck might seem identical a wheel/BS choice might not work on another. For instance with the 67-72 truck models there was actually two different size rear ends used; this would greatly affect the correct BS required for your application.
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 12-28-2008 at 10:11 PM. |
Re: New Wheels?
Sorry, didn't see you were looking at 22 inch rims
I just put 15 inch chrome rallies on my 67... it has 5 lug conversion with disc brakes and the narrow rear end. 4.5 backspacing on the front was too much and rubbed the calipers (could be a 15 inch rim issue) 5 inch backspacing on 10 inch rear worked but left too much gap due to narrow rear end. Had to use spacers... 8x15 with 4in BS front & 10X15 with 4in BS would of been perfect for my truck. But like was stated, not all trucks the same and larger rims could probably get away with more in the front. I went with more backspace in case I was wrong... nothing you can do if they stick out too much... Last edited by Mondo; 12-29-2008 at 05:45 PM. |
Re: New Wheels?
Thanks guys. Anyone running 22"s all the way around?
Re: New Wheels?
yeah im going to run 22's all the way around my 72' cheyenne lwb. . . will post up pics when i get the rims
