01-03-2009, 11:42 PM | #1 |
72 K-10 AC Removal
Removing the AC system from my 72 K-10 because most of it is missing. I have the under hood portion figured out and have found a source to allow removal of the under hood housing. Here is the question, can I replace the underdash ac hard plactic ducting with a none ac hard plastic ducting? (I know the flexable air ducts are not a problem) The cabling, wiring and actuators are different but is that the only differance? Will mount in the same location?
Thanks |
01-04-2009, 08:36 AM | #2 |
Re: 72 K-10 AC Removal
Welcome to the 67-72 Truck Board from West Michigan!
If you are wanting to replace the AC with the standard heater setup then it is a little bit of a project. The firewall holes for the AC and standard heating are different. It can be done but the question is : Will AC become desireable in the future?" AC in our trucks can be nice! Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-04-2009, 02:30 PM | #3 |
member #16
to the board. Heres the difference.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
