Moderator
![]() Join Date: May 2007
3/4 ton question
I just picked up a really nice loaded 72 C-20 survivor, and was wondering if there are parts made to lower it just like a 1/2 ton truck? It has spindles in the front (8 lug all the way around) and leaf springs out back, and it looks like also it has overload or helper springs. I have seen lowering leafs made and was wondering if they have them for the 3/4 trucks also? Thanks in advance.
Also- Do they make rally wheels in 8-lug? I really dont want to change my axles and rotors if I can help it. Last edited by leddzepp; 01-08-2009 at 11:23 AM. |
Between Trucks...
Re: 3/4 ton question
I've seen drop spindles for C-20's around don't remember who carry's them though, maybe Classic Parts? Don't know about the lowering leafs. How about a flip kit?
Beat it to fit, Paint it to match... ![]() |
its all about the +6 inches
no rally wheels, some people like the ugly silver wheels with center caps in the 90's 2500 truck for some reason, others will call them rallys. But they aren't. They are just silver steel wheels.
You can use drop springs up front, have drop spring pocket lower control arms made, or raised ball joint LCA, and I *THINK* there may be a lowered 8 lug spindle made... but I am not sure. out back with the leafs, you can do a flip kit, and then raise it a little, or just leave it and C notch depending on desired drop. |
Moderator
I will check around to see if there is an 8 lug drop spindle. I have also seen dropped leaf springs, but I am guessing that they are different for 3/4 ton than 1/2 ton. How difficult is it to do a flip kit? Do they make one? Thanks again. This truck rides very smooth and I want to keep it that way as much as possible.
![]() Join Date: Oct 2007
I have leaf springs with a drop on my truck and there are a lot to take into consideration when ordering new leaf springs with a drop ..Believe me I found out the hard way so if you decide to go that route ,,give me a PM and I will fill you in on what all has to be considered for an exact to the inch drop you would want ..
Larry |
Moderator
Larry- Is your truck a 3/4 ton also?
They do sell drop spindles at Performance online. That is going to be my next move. I used 3" drop coils in the front and in the rear I installed some drop shackles, took half the leaf stack out and had the leafs springs re done with an addtional 2" drop. The back I was able to drop by almost 7". I don't plan on hauling with the truck... just ride in comfort.
1972 c-20, 350/350, dana 60 w/456 gears(no Posi) |
Running on empty
_____________________________________________ Tim We have two rules here at the Rock. Rule #1: No writing on the walls. Rule#2: Obey all rules 70 GMC Sierra Grande "Custom Camper" Longhorn 402 Big Block TH400 PS PB factory AC Posi; 94 Bronco XLT 302, auto;worn out daily driver ![]() |
#10 | |
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
![]() Quote:
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
Moderator
Total Chevy- Thanks for your info, and VERY nice truck! I want to get some pics of the truck I just got and post them this weekend. I see that CPP sells the drop spindles for the C-20...I also see they sell the shackles to lower the rear by 2"...just wondering if they fit both 1/2 and 3/4 ton and if the mono leaf drop leafs will also fit the 3/4 ton trucks
#12 | |
Moderator
That sounds like a good way to go to save money...so the mono leafs will work for 3/4 ton also??
I bought a set of those drop shackles. They do drop it 1-2", but the top of the shackle hits the bed. When I inquired as to the problem, I was told they wouldn't work on a 3/4 ton. They were made for 1/2 tons only. There was no mention of this fact in the description. They took them back, but were very reluctant to do it. Might save yourself the hassle, and look at other means to lower it. My $.02 .
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
#15 |
Moderator
Thanks for the input Dan. I do want to go more than 2" on the drop and I figured the shackles would hit. I used to lift Jeep CJ's so I am in familiar territory with leaf springs. How are them speakers workin out for ya?
#16 |
![]() Join Date: Nov 2007
Welcome to the C-20 world of beasts !
![]() Its all gravy until the registration comes around yearly.. $229 for my C-20 ![]() I remember a thread here where someone lowered a 3/4 ton. It looked nice and may have been in SoCal member If I remember correctly.
72 C20 Longbed 05 1500 Z71 Last edited by sleepertruck72; 01-08-2009 at 07:33 PM. |
#17 |
Probably won't try the speakers until spring. To cold to go out in the garage now. Have to strip and paint the mounts first.
#18 |
Moderator
Why is your registration so high?
#19 |
I wish I knew.. the reg fee is $59 or so and they add a "weight fee" of $159 or something like that along with county fees... one fee after another. The DMV wont budge on the fees
Here is the link to the nice lowered c-20 in SoCal. Wow my memory is still working somewhat ![]() http://67-72chevytrucks.com/vboard/s...t=c-20+lowered
72 C20 Longbed 05 1500 Z71 |
#20 |
Cali screws ppl hard when they can. All pick ups are registered as comercial vehicles. About the only way you can *TRY* to get around that is with a campershell on the back.
#21 |
Moderator
My other 72 is only $40 a yr to register, and it is also considered a commercial vehicle. I had to get it weighed on a grain scale.
No arguement there...Cali does screw people hard when they can. Luckily, any vehicle 1975 and older is emmissions exempt. Go figure...we have the toughest smog laws in the country, and yet the ones that pollute the most are exempt ![]() Last edited by leddzepp; 01-08-2009 at 08:10 PM. |
#22 |
Invest in Gold!
![]() Join Date: Sep 2007
How many pre 75 cars and trucks drive around every day? I don't think they contribute to smog that much.
John Gold 1970 Chevy LWB Fleet |
#23 |
Moderator
#24 |
R.I.P. E.S.L.L.
![]() ![]() Join Date: Aug 2005
Mine was $149 last time, but it is nice not to worry about smogging it.
I think the tags are going up though because my old 68 VW was $75 last time (last week) and its definitely not a commercial vehicle ![]()
1971 Custom C/20 ![]() 1970 CST 20 1970 C/30 Flatbed 1983 C/30 Dually 2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350. R.I.P. El Jay R.I.P Jessie. R.I.P Grumpy. Every day is a gift from God. |
#25 |
$138 for Reg in Calif 1970 C-20 empty weight 4200 Lbs. I rarely see any pre 75 vehicles on the road, there contributions to smog are minimal at best.I would look at planes, trains, commerical trucks, even buses( around the clock polluters) as the biggest sources. Most commuters only drive 1/2 hr to 1 hr a day in very clean late model cars.
