Picture needed PLEASE!
I finished the disc brake conversion today. Well almost. I wanted to swap the centerlink also. Everything came off a 71. My question is where do I drill the holes at in the frame? I bolted up everything. Tie rod ends, Hooked up the steering on the drivers side. Then hooked up the tie rods on the passenger side. The arm (don't know what it is called) that bolts up to the frame is way different than my 63. I have seen this swapped over and was told that you had to drill some holes. I hope I have explaned what I need well enough. Any pictures or info will be very helpfull. Thanks Dustin
TexasBowhunter
Re: Picture needed PLEASE!
Pitman arm?
Build in progress for son's first truck. |
This is what I'm talking about. Not sure what it is called. Please help!
Resistance is Futile
That is a drag link, I believe.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
In House Collision Technician
that's an idler arm.
1 thing at a time is progress.
![]() I leveled my frame from side to side. I then leveled the center link and measured from crossmember to get it even then clamped the idler and drilled. ![]()
Alan
Philippians 2:14-16 |
