Old 03-02-2009, 12:59 PM   #1
87Bob
Interval wiper Steering column photo
I have an 85 that I am putting a tilt column in to. I have it torn down to replace the key cylinder. So I have the top of the column all apart. Since my truck did not come with interval wipers I'd like to add them. Does anyone have a picture (or can snap one) of the module for the interval wipers mounted on the column? That way I can see where it goes. Thanks in advance!
Bob
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 03-02-2009, 05:30 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Interval wiper Steering column photo
Can someone help him?
tvblazer78 is offline   Reply With Quote
Old 03-03-2009, 09:24 AM   #3
87Bob
Ttt
Old 03-04-2009, 07:17 AM   #4
87Bob
Ttt
Old 03-04-2009, 12:00 PM   #5
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I'll get some pics of mine during lunch today and post them tonight when I get home for ya.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-04-2009, 03:02 PM   #6
87Bob
That would be very much appreciated I have an 85 Shop Manual and it does not show it anywhere. it makes the following reference which is as clear as mud. "Light duty trucks use a separate control assembly to operate the wipers over a variable delay of 1 to 20 seconds. The control assembly plugs into the selector switch at two different connectors. One of these connectors has a piggy-back connector that connectors to the regular wiper harness. There is also a lead from the control that plugs into the accessory cavity of the fuse panel. Thanks to anyone that help decipher all this nonsense!
Old 03-05-2009, 02:49 PM   #7
87Bob
ttt
Old 03-05-2009, 10:18 PM   #8
BLE 'BURBAN
Hey sorry about not posting last night but got caught up with other things here.
Anyways here's the pics I promised for ya.
Under the column remove the lower dash access panel
Then you will be able to see the wiper control module (if you've got one)
If not then you can add one in but you'll need to change out the switch as well as the lever (arm)
Heres a pic of the topside of the module Note that 2 of the 4 claws are busted off on mine. (my stupidity)
And lastly of the mount itself on the underside of the column
Hope this helps y'all out!!!
Old 03-06-2009, 10:25 AM   #9
87Bob
Man that is awesome now I know what I am looking for at the you pull it parts yard. I am assuming that the exisiting column harness plugs into the module on one side and the pigtail connects to the other end of the exisiting harness. Thanks for your post! You DA Man!
Old 03-06-2009, 10:58 AM   #10
tvblazer78
Low & Fast!
tvblazer78's Avatar
Thanks for helping him out BLE 'BURBAN
Old 03-06-2009, 11:08 AM   #11
BLE 'BURBAN
Anytime.
I may be slow but I get the job done.............................eventually
Old 03-06-2009, 04:40 PM   #12
87Bob
Ble Burban your photos made all the difference in the world. I went to the Pick A Part and for 4.00 got what I needed thanks!
Old 10-22-2009, 03:55 PM   #13
joe231
joe231's Avatar
Hey BLE
can you repost your pics, please?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 10-22-2009, 11:27 PM   #14
BLE 'BURBAN
Originally Posted by joe231 View Post
Hey BLE
Done deal!!! LOOK UP!
Old 10-23-2009, 10:24 AM   #15
joe231
joe231's Avatar
right on!!
thanks!
sorry to 'jack the thread, but.......
another question.......does anyone have a wiring diagram for the delay wipers on a '85(switch on the turn stalk) and a delay diagram for a '80 (switch on the dash).
all the diagrams I have found just show a 2 speed switch, no delay. I'm converting my '80 to the '85 up wiper delay switch/module set up.
The P.O. had already swapped in the newer tilt column....
Thanks!
CHEVY ONLY
Old 11-17-2009, 09:32 AM   #16
68 TT
Still plays with trucks
68 TT's Avatar
right on!!
thanks!
Thanks!
^ x2
My 78 desperately needs delay wipers and when I put the overdrive auto column in there it will have the control stalk type wiper controls.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 10-26-2009, 07:29 PM   #17
joe231
joe231's Avatar
Alright, I'm an excellent thread jacker.....so I will continue.
I got a junkyard wiper module from a '89
I have everything but intermittent wipe.
Anyone have specs on troublshooting the switch and the module.
I get a resistance change when you adjust the switch, but I'm unsure what value it should be. I'm figuring that I got a bad module, but I would like to be able to condemn it for sure. Can't complain too much, the module only cost me $5.....there were several other modules at the pick and pull, is there a way to check them with a meter to see if they are any good?
Ramble over, thanks
CHEVY ONLY
Old 11-17-2009, 02:07 AM   #18
Alaskaskiff
Check the brown/wht to brown wires coming off the switch side where the Pulse Wiper Module goes. Run the switch through its cycle. You should see a range of 50 to 500 K Ohms. If within that the switch is good. If you have it hooked up then the module is bad. If not in that range the switch is bad. Source: 86 FSM.
Alaskaskiff is offline   Reply With Quote
Old 11-17-2009, 02:57 AM   #19
BLE 'BURBAN
HOT DAMN!!! ANOTHER ALASKAN ON HERE!!! WELCOME ABOARD SIR!!!
And welcome to your latest addiction as well!!!
Dave here. Working in the parts dept @ Ak sales & Service
Old 09-15-2010, 02:43 PM   #20
kikkegek
kikkegek's Avatar
he man! I see you got the 86 FSM. I got a 86 model Suburban K20 Silverado model and my Interval mode is not working. Loand High are fine though. Can you please see if there is a procedure I can use to check out what is causing my failure?
thanks a lot man! also sent you a pm
kikkegek is offline   Reply With Quote
Old 09-16-2010, 11:28 AM   #21
Slonaker
Insert Witty Text Here
Slonaker's Avatar
If you find a way to test them, I would appreciate it if you would share the info with me. My situation is the same as yours. Everything I have ever read on here says that there is no test procedure known.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 09-16-2010, 05:46 PM   #22
CaliDude76
All About the BOWTIE
CaliDude76's Avatar
I did the same thing.. not long ago.... I put a tilt column from a Silverado with all the goodies on the turn signal stalk..
My stock column didn't have tilt, nor did my truck have Intermittent or cruise either... Tilt works great... no cruise (of course).. but the wipers work good on high and low.. through that module the tilt column came with... now in order for the intermittent to work.. do I need to add a different type motor, or something else that my truck doesn't have??
Or is it just the module, and having the actual dealy wiper stalk all I need? (and maybe just have a bad module)
BTW.. My truck is an 84 (Custom Deluxe),.. and the donor came off of an 84 as well...(Silverado)
CaliDude76
"... Being "SQUARE".. is where it's at...."
Proverbs 15:30 .... "A Cheerful look brings joy to the heart, and good news gives health to the bones..."
Be exceedingly blessed today, my friends!...
CaliDude76 is offline   Reply With Quote
Old 09-16-2010, 07:24 PM   #23
joe231
joe231's Avatar
yep, the motors are the same only difference is the delay switch and the module
CHEVY ONLY
Old 11-17-2009, 09:57 AM   #24
joe231
joe231's Avatar
Thanks Alaskaskiff!!!!
BLE'
I'm Alaskan at heart.....That ought to count for something, right?
I miss it bad!
CHEVY ONLY
Old 02-16-2015, 06:22 PM   #25
Hart_Rod
Hart_Rod's Avatar
Great info from an old thread!
Hart_Rod is offline   Reply With Quote
