Old 03-27-2009, 07:56 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
A 70 GMC now
This is a 70 GMC C20, I will be parting it out as usual Ask questions in thread. Pay pal or money order. Thanks Randy
Exhaust manifolds $50 plus shipping for pair-SOLD
4 speed high hump $25 plus shipping
4 speed steering column $40 plus shipping-SOLD
V8 motor stands $30 shipped
Good radiator support, $50 sale pending
metal door panels, drivers has a couple small dings and a ring where the window crank rubbed, pass is is beat up bad $10 plus ship
See anything else you may want ask and I'll price, Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 03-27-2009, 08:08 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: A 70 GMC now
would you consider clipping the header pipes out ( not the rams the acual pipes) with the clamp ring?? the E brake cables,and I need a upper radiator support hold down for a 4 core I have a 70 I'm trying to put together on a low budget
thanx jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-27-2009, 08:16 PM   #3
Wootdog
Wootdog's Avatar
Re: A 70 GMC now
Randy,
I need a passenger door. I know you normally don't ship the heavy and or big parts, but I need a right door.
Kerry
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 03-27-2009, 11:57 PM   #4
teeitup
teeitup's Avatar
Re: A 70 GMC now
Hottrucks, how much of the exhaust pipes you needing? Sorry it doesn't have any E-brake cables on it. No upper 4 core mounts, I'll look and see if the lowers are there.
Wootdog, Kerry, sorry I still don't mess with shipping doors
Thanks Randy
1980 chevy swb 4x4
Old 03-28-2009, 12:29 AM   #5
bad421
bad421's Avatar
Re: A 70 GMC now
how much would shipping on the 4spd column be to Va. 23061? thanks
ASE MASTER TECH
  • 1968 K10 LT1 350,SM420,T-221 lwb fleetSold
  • 2007 Ford Ranger DD
  • 2000 Ford F250SD V10 4x4
  • 1968 Pontiac Firebird 468/TH400 current project
  • 1991 Dodge W350 SRW CUMMINS POWERED
Whole lotta fuel and a whole lotta Smoke
bad421 is offline   Reply With Quote
Old 03-28-2009, 12:54 AM   #6
gottwake
gottwake's Avatar
Re: A 70 GMC now
Do you have these two parts? They are the Steering column front and support plates.
Blazer Project
gottwake is offline   Reply With Quote
Old 03-28-2009, 05:40 AM   #7
Hottrucks
Hottrucks's Avatar
Re: A 70 GMC now
randy I would take as much as it has or is easy to get out I'm going to have to build a full exhaust anyway..I need the steel plate that hold the rad not the rubber so much..and the splash well from the drivers side bed ( THE LITTLE PART FROM THE WHEEL WELL TUB TO THE BOTTOM OF THE FENDER) sorry caps) \
I'm just tearing into this so I may need more stuff as I get though today
thanx
jeff
Old 03-28-2009, 08:38 AM   #8
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
Re: A 70 GMC now
i need the ignition switch spacer shipped to 95901? thanks
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 03-28-2009, 10:45 AM   #9
teeitup
teeitup's Avatar
Re: A 70 GMC now
bad421, I'll get a quote this weekend for you
gotwake, Yes I have both of those $20 shipped for pair, I know I have the four lower bracket bolts, but unsure if I have the upper one, but I'll look
Hottrucks, Jeff, I can cut it past the bend no problem $15 for pair, the upper 4 core brackets are not there, sorry. The bed splash pan is $10, so $25 plus shipping for what your asking about?
vasquezmrysvll, sorry it doesn't have a key in it for me to pull the ig switch. I could cut the whole switch out for you. $15 shipped?
Thanks let me know guys, I'm not going to be able to do much today, Sleeting, snowing and Wind is BLOWING hard today, Randy
1980 chevy swb 4x4
Old 03-28-2009, 11:09 AM   #10
Curbstone Mech
Active Member
Re: A 70 GMC now
Randy=
How are the headlight trim rings?
Shipping to 21157?
Thanks!
68 short fleet
383 stroker, 700r4 373:1 posi
72 GMC 3/4 ton- weekly driver
700r4 351;1 posi
Curbstone Mech is offline   Reply With Quote
Old 03-28-2009, 04:08 PM   #11
teeitup
teeitup's Avatar
Re: A 70 GMC now
I'll have to check them out, I never looked at them. It will probably be Sun befoer I get out there. Thanks Randy
1980 chevy swb 4x4
Old 03-28-2009, 07:04 PM   #12
Hottrucks
Hottrucks's Avatar
Re: A 70 GMC now
thanx T cut it as far back as you dare and I'll take the splash pan too
let me know what shipping is I'll pm you my addy
thanx Jeff
Old 03-28-2009, 09:21 PM   #13
teeitup
teeitup's Avatar
Re: A 70 GMC now
Hottrucks, Jeff, it will probably be Mon after work before I get out there to cut them off. Thanks Randy
1980 chevy swb 4x4
Old 03-29-2009, 08:18 AM   #14
Hottrucks
Hottrucks's Avatar
Re: A 70 GMC now
no biggie I'm not in a big rush
Old 03-29-2009, 09:34 AM   #15
stope4
Re: A 70 GMC now
Randy, if the dash isn't cut I am interested in the dash around the radio and ac.
stope4 is offline   Reply With Quote
Old 03-29-2009, 10:03 AM   #16
teeitup
teeitup's Avatar
Re: A 70 GMC now
I think I may end up being out there today pulling a motor out of the 68, I'll try to look at everything everyone has asked about and hopefully have time to get some of the parts off.
Stope, this truck doesn't have AC on it? Wan't sure if you were needing one with AC or not?
Thanks Randy
1980 chevy swb 4x4
Old 03-29-2009, 09:05 PM   #17
teeitup
teeitup's Avatar
Re: A 70 GMC now
Curbstone, the driver side has a dent in lower middle and one on the outside lip and some surface rust, pass looks OK. $12 plus shipping for pair
Hottrucks, got your stuff off but I need to get a box to figure shipping, I'll do that Mon after work.
Stope4, its in good shape $15 plus shipping
Thanks let me know guys, Randy
1980 chevy swb 4x4
Old 03-29-2009, 10:24 PM   #18
stope4
Re: A 70 GMC now
need one with ac. thanks
Old 03-30-2009, 12:25 AM   #19
MonteSS454
MonteSS454's Avatar
Re: A 70 GMC now
Grille, surrounding trim and core support?
Condition of those and prices please. I'd pick up instead of shipping.
MonteSS454 is offline   Reply With Quote
Old 03-30-2009, 06:00 AM   #20
Hottrucks
Hottrucks's Avatar
Re: A 70 GMC now
t hold up a sec I just bought a parts truck yesterday so I need to se what it has on it I'll be picking it up wed eve
thanx Jeff
Old 03-30-2009, 08:17 AM   #21
teeitup
teeitup's Avatar
Re: A 70 GMC now
stope4, I'll have one coming in a truck next week
MonteSS454, grill and surround is all dented up. Core support is pretty decent, I'll get pics later today of it all, $50 for it.
Hottrucks, thats fine just let me know
Thanks Randy
1980 chevy swb 4x4
Old 03-30-2009, 07:07 PM   #22
MonteSS454
MonteSS454's Avatar
Re: A 70 GMC now
Ok, thanks if the core is as good as you say I'll be pming you.
Old 03-30-2009, 09:37 PM   #23
teeitup
teeitup's Avatar
Re: A 70 GMC now
Monte, here are some pics, part of the inner fender is still bolted to it on both sides. It has one spot where there is rust, see pic, it is not through. The area below the battery tray on the bottom side is pitted but not rusted through. Thanks let me know, Randy
1) whole support
2) drivers side top
3) driver side bottom
4) pass side top
5) Pass side bottom
1980 chevy swb 4x4
Old 03-30-2009, 09:39 PM   #24
teeitup
teeitup's Avatar
Re: A 70 GMC now
Here is the small rust area
1980 chevy swb 4x4
Old 03-30-2009, 09:41 PM   #25
teeitup
teeitup's Avatar
Re: A 70 GMC now
More parts
1980 chevy swb 4x4
