Old 05-23-2009, 07:37 PM   #1
dreamtruckproject
Show me your exhaust
Hey guys, mostly I am just a lurker around here trying to soak up as much knowledge as I can. But I am in need of some ideas for exhaust routing. I will be running a sbc with a granny 4 speed and a gearvendors overdrive. I have some magnaflow mufflers I want to use that are 24" in length and are for 2.5" exhaust. I would like to have the exhaust dump over the axle or exit out the side under the step on the stepside. I have ramhorns, and 89 factory truck exhaust manifolds, but am also considering aftermarket block huggers, shorty headers, or full length headers. I guess it all depends on exhaust routing. Just need some good ideas for options. Thanks.
63 Chevy short step
dreamtruckproject is offline   Reply With Quote
Old 05-28-2009, 05:31 AM   #2
TwinTurbo
TwinTurbo's Avatar
Re: Show me your exhaust
Under the step is what I have....
TwinTurbo is offline   Reply With Quote
Old 05-28-2009, 11:42 AM   #3
slepysal
slepysal's Avatar
Here is mine old bellflower tips before paint
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 05-28-2009, 01:01 PM   #4
4dranch
Shloooooong bed member #2
4dranch's Avatar
here's mine on my 305 V6....
David,
Daughters 66 truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=484601
Learning to drive a 3 on the tree:
http://www.youtube.com/watch?v=CcCMvRgBo1Q
4dranch is offline   Reply With Quote
Old 05-28-2009, 04:24 PM   #5
dreamtruckproject
Hey 4dranch, that looks about the same as how I have figured I will have to go. What are the length of your glasspacks? Am I seening correctly that you are using the bellhousing crossmember mounts? And using stock manifolds I assume?
I am going to be using the stock style manual bellhousing (machined for a SM465) and side mount crossmember. I have tried fitting the mufflers abouve the trailing arms to dump on the rear axle. But I think the side exit under the step has a better look. Will headers fit using the sidemount bellhousing crossmember?
63 Chevy short step
Old 05-28-2009, 07:18 PM   #6
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Just my .02 worth. I just replaced my exhaust (done by P.O.) removing it from dumping out in front of the rear wheels to straight out the back. Dumping out in front of the rear wheels is good way to ruin some nice wheels. Also the engine always sounds like it has a miss since you only hear half of the engine. Out the back sounds much better and it is not staining my aluminum wheels with carbon.
66Gilbert is offline   Reply With Quote
Old 05-29-2009, 06:51 AM   #7
4dranch
4dranch's Avatar
[QUOTE=dreamtruckproject;3331858] What are the length of your glasspacks? They are turbo tubes and they are 24" And using stock manifolds I assume? Yes they areQUOTE] Here are some more shots, hope this helps.
David,
Daughters 66 truck:
Old 05-28-2009, 01:29 PM   #8
slepysal
slepysal's Avatar
Attachment 465434
Oh L6 250 with headers ,dual 15" glass pacs just a little loud
Old 05-29-2009, 08:49 AM   #9
70 Suburban
Rods
I HAVE DEALER STEPS CUT INTO THE SIDE OF MY FLEET 66. i AM GOIN TO POLISH THEM AND RUN MY EXHAUST THERE. i AM WANTING TO RUN THE EXHAUST ON THE OUTSIDE OF THE FRAME TO JUST INFRONT OF THE REAR TIRES
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 05-29-2009, 02:17 PM   #10
SIR
SIR
SIR's Avatar
will this work?
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 05-29-2009, 11:16 PM   #11
sidthirteen
sidthirteen's Avatar
sidthirteen is offline   Reply With Quote
Old 06-12-2009, 01:00 PM   #12
72 SHORTBED 7.0
72 SHORTBED 7.0's Avatar
Originally Posted by SIR View Post
will this work?
Now that was to funny Had to show this to my son
72 SHORTBED 7.0 is offline   Reply With Quote
Old 05-29-2009, 11:27 PM   #13
shortbed70
shortbed70's Avatar
mine, Block huggers,2.5" straights to s bend, flowmasters mounted under bed.
Next time I'm going to run outside the frame and turnout in front of tires.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 05-29-2009, 11:57 PM   #14
dreamtruckproject
Thanks that helps a lot. I just decided today that I will be running it the same way.
63 Chevy short step
Old 06-02-2009, 07:10 PM   #15
sotxpanrider
This is the exhaust tips of my ol 65. I have always like the zoomies.
sotxpanrider is offline   Reply With Quote
Old 06-02-2009, 07:25 PM   #16
64Magoo
Not much but here was mine...
64Magoo is offline   Reply With Quote
Old 06-03-2009, 04:01 PM   #17
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Show me your exhaust
Me likes zoomies too!!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-03-2009, 05:05 PM   #18
Sillyoldman
#16876
Sillyoldman's Avatar
How do they sound? I've been thinking about doing the same. I don't have pipes yet.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 06-03-2009, 05:08 PM   #19
MacAttack
283 Drama Queen
MacAttack's Avatar
Can't show you mine - rig's on the tow truck in 20 minutes.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 09-26-2010, 12:10 PM   #20
60apache
60apache's Avatar
thats what I did with mine
60apache is offline   Reply With Quote
Old 09-26-2010, 01:35 PM   #21
1Bad62Pro/Street
Well,
I guess I can update my exhaust on here now.
The exhaust is home made! They are made out of Driveshafts!
One Bad Mamma Jamma's
(PoeMasters 2010 Series Custom Exhaust).........
Why buy Flowmasters when you have the PoeMasters!
Deep Aggressive. Powerful Sound!
While at idle a Exhaust Note that Demands Respect!
Poe....Poe....Poe....Poe....Poe....Poe....Poe....Poe
Taking orders now!
1-800-POE-MSTR
Pictures here:
http://67-72chevytrucks.com/vboard/s...d.php?t=321173
Old 06-02-2009, 07:24 PM   #22
66chevy PROSTREET
SOLD
66chevy PROSTREET's Avatar
Location: Poorest state in America(Breaux Bridge,Louisiana)
heres mine getting modified....again
1966 CHEVY FLEETSIDE
SOLD 11-29-9
TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2
66chevy PROSTREET is offline   Reply With Quote
Old 06-03-2009, 01:00 PM   #23
jchav62
1962 C-10
jchav62's Avatar
I used to run Flowmaster 40's with 2.5" pipe, straight out the back with "Megaphone" tips.
I later switched to Cherrybombs with Bellflower tips...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-03-2009, 04:49 PM   #24
joe231
joe231's Avatar
which sound do you like better?
still have the flows laying around?
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-04-2009, 09:15 AM   #25
jchav62
1962 C-10
jchav62's Avatar
I like how both setups sound. I believe the truck has to sound how it looks. So since I went more old school looking, I wanted it to sound that way. I'm a fan of both Flows and packs.
The flowmasters are gone...traded away...
Joseph Chavez
