Old 05-31-2009, 11:15 AM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
pvc valve
ok i noticed that my right valve cover it smokes a little while running so i took off the breaker and noticed there was no suction so i ripped some of the foam out of the breather so it would breath easier but then i noticed my carb isn't sucking any air from that line...its the blue hose on the front of the carb
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 05-31-2009, 12:08 PM   #2
Longhorn321
Size Matters
Longhorn321's Avatar
Re: pvc valve
Did you check for vacuume at the end of the hose or at the carb?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 05-31-2009, 12:18 PM   #3
pokethesmot
Re: pvc valve
at the carb
Old 05-31-2009, 12:27 PM   #4
pokethesmot
Re: pvc valve
nvm i checked it again and im getting vacuum its just like a month ago i checked it and it wasnt getting any
Old 05-31-2009, 11:04 PM   #5
Longhorn321
Size Matters
Re: pvc valve
When u say right V/C...do you mean right from the drivers seat or right when looking at the front of the truck?
NVM...just re-read your OP. Are you getting any suction from the pass. side V/C when you pull the filter off?
...WOOOO HOOOO!!!!
Old 05-31-2009, 11:18 PM   #6
pokethesmot
Re: pvc valve
i mean right valve cover like driver side that one is smokin and the passenger side is just fine
Old 05-31-2009, 11:25 PM   #7
Longhorn321
Size Matters
Re: pvc valve
Pull the filter offf the other side and see if the smoking stops. If it does..replace the filter on the pass. side.
...WOOOO HOOOO!!!!
Old 06-01-2009, 01:21 AM   #8
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: pvc valve
I've seen those breathers not have the hole punched out and will not flow any air.
heavychevy79 is offline   Reply With Quote
