Old 06-10-2009, 09:27 AM   #1
blue1972
blue1972's Avatar
72 Blazer Rear Disc Brake Conversion - help.
This is my first time posting. Were can i find the least expensive disc brake conversion kit for my 72 blazer? My rear drums are shot.
I really appreciate anyones help.
blue1972 is offline   Reply With Quote
Old 06-10-2009, 09:40 AM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: 72 Blazer Rear Disc Brake Conversion - help.
ECE has a nice kit. easy to install and they are the best people to deal with.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 06-10-2009, 11:04 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
http://www.blackbirdscustomtrucks.com/ also makes a kit. One of the guys that works/worked there is/was a board member (drink2mny).
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 06-10-2009, 08:49 PM   #4
BLUE THUNDER
BLUE THUNDER's Avatar
Summit might have something under $500.00 bucks. Hope that helps.
BLUE THUNDER is offline   Reply With Quote
Old 06-25-2009, 09:36 PM   #5
capev86
i do not care for any rear disc kit that has the e-brake in the caliper....to complicated and a chance for things to seize up. much better to have a drum brake e-brake that is housed behind the brake rotor. 87-88 daytonas had the former style and it was very problematic. 1989 and newer dodge fwd's (and neon's) with rear disc had the later/better style that is problem free and much easier to work on.
remember that a drum shoe has a larger swept area than a disc pad and so works great holding a vehicle still and the shoes only need to be replaced due to extreme age when the linings fall off the metal part. i'd prefer to use a factory rear disc brake package from the same manufacture (GM in this case) so that parts are easy to get. i bet a lot of aftermarket brake kits use their own pads and parts, etc so not easy to just go down to the local store. i want to put 3/4 ton 2000+ rear disc on the back of my 72 burb 2wd 8 lug. if i too much money, i'd swap out the 10.5 FF 14 bolt axle for a 2000+ 11.5 FF axle.....that would totally killer.
capev86 is offline   Reply With Quote
Old 06-26-2009, 09:13 AM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I have the McGaughy's 13" Rear Kit, Not installed yet.
LUV2XCLR8 is offline   Reply With Quote
Old 06-27-2009, 05:34 AM   #7
vtblazer
vtblazer's Avatar
Stock axles?
Might be easier to just repair your existing drums IMO.
Repairing those would only take an afternoon in the driveway as oppossed to the amount of work needed to go disc.
Plus, add in the fact that not all disc kits have e-brake capacity, then there's even more work.
vtblazer is offline   Reply With Quote
Old 06-27-2009, 12:52 PM   #8
RED72blazer
urban fourwheelin
RED72blazer's Avatar
Originally Posted by vtblazer View Post
Stock axles?
I agree. the rear brakes on these things are easy and fairly cheap except for drums. Still it will still be cheaper than disk. I can understand wanting to install rear disk brakes. Possibly in hopes of better stopping power. But I don't think it is worth the hassle. I wonder if it will make a difference in braking. I'd really like to get mine to stop better. But I think I will try the 3/4 ton M/C swap first.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage.
RED72blazer is offline   Reply With Quote
Old 06-28-2009, 06:00 AM   #9
vtblazer
vtblazer's Avatar
That's the best first step, 2nd step is to loose the rubber brake lines and replace em with a set of stainless steel braided lines, those two thing's alone will make a big difference believe it or not.
Old 06-28-2009, 07:18 PM   #10
Frizzle Fry
Frizzle Fry's Avatar
I'm surprised no one has mentioned Glock's brackets for camaro/caprice rear discs: LINKAGE I think I did mine for around $400 total.
Frizzle Fry is offline   Reply With Quote
Old 06-29-2009, 11:05 AM   #11
blue1972
blue1972's Avatar
Thanks guys! I really appreciate the help. I think i might just try rebilding the drums, and upgrading the brake lines first.
Old 06-29-2009, 08:05 PM   #12
drink2mny
drink2mny's Avatar
Well let me know if you have any questions about our kits.
Support The Board
drink2mny is offline   Reply With Quote
Old 06-30-2009, 09:53 PM   #13
daddys72jimmy
daddys72jimmy's Avatar
hey blue i got 2 factory calipers and 2 rotors from kragen and ordered a rear disk brake bracket kit w/hardware from ebay. total was about 400 $s
daddys72jimmy is offline   Reply With Quote
