Old 08-05-2009, 02:03 AM   #1
anythingonwhlz
1970 Blazer body differences between 2wd and 4x4
I need to know exactly what the differences are between a 1970 Blazer 2wd body tub and a 4x4 body tub. I do know the removable trans tunnel is different, what else is different. Reason being is I have a verv very nice 4x4 Blazer and a some what rusted out 2wd Blazer which I plan to do a body swap. I will be keeping the vins and matching 2wd chassis and sitting the 4x4 tub on it. Any and all responses are greatly appreciated.
anythingonwhlz is offline   Reply With Quote
Old 08-05-2009, 05:45 AM   #2
vtblazer
vtblazer's Avatar
Re: 1970 Blazer body differences between 2wd and 4x4
Non that I'm aware of, why would you expect the two to be different?
vtblazer is offline   Reply With Quote
Old 08-05-2009, 10:47 AM   #3
anythingonwhlz
Im not sure. But if there is to be a difference Im sure someone on this site will point it out.
Thanks for your time
Old 08-05-2009, 02:55 PM   #4
fxdxharley
Just a nother gear head
fxdxharley's Avatar
what about like the body mounts area in back? with the frames being diff, the mounts would be i would think.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 08-05-2009, 08:46 PM   #5
blazerboy72
My 2wd and 4wd both have the same body mounts just on the 2wd one of them doesnt connect to any thing on the frame. The only difference I know of is most 2wds come with a low hump and most 4wds have the high hump.
blazerboy72 is offline   Reply With Quote
Old 09-25-2009, 11:30 AM   #6
TonyJohnson
TonyJohnson's Avatar
So what's the frame difference? I just found a 2wd crossmember and front suspension setup that I was planning to use on a Jimmy 4x4 conversion to 2wd. I thought the crossmember would just bolt up...
Tony Johnson
-- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer --
TonyJohnson is offline   Reply With Quote
Old 09-25-2009, 01:13 PM   #7
1sik52
it will
1sik52 is offline   Reply With Quote
Old 09-25-2009, 01:14 PM   #8
TonyJohnson
Cool. Thanks!
Tony Johnson
Old 09-25-2009, 01:25 PM   #9
Thealien
Thealien's Avatar
I believe the difference is in the rear of the frame. On 2wd the frame flares out to accept the top of the coil springs on the trailing arm 2wd trucks. The leaf spring frame is different. I am also researching this so I am hoping those that know more than I will speak up.
BTW what did you pay for the crossmember and front suspension?
Old 09-25-2009, 01:31 PM   #10
TonyJohnson
It's a 5 lug disk setup that's pretty rusty. I'm paying $200 because he's giving me all the pieces. Seems a little high, but folks are buying these just to do the disk upgrade... I haven't got the pieces yet and we're playing email tag, so it's not a done deal...
Tony
Tony Johnson
Old 09-25-2009, 08:10 PM   #11
ABLAZN
Oh..never mind....
ABLAZN's Avatar
Tony
$200 is not to bad of a deal, ECE wanted $350 just for the front suspension and engine cradle , plus shipping, most likely $450 or more total from them. I got lucky and found a 3/4 ton complete front end for $50, but I have to use an ECE conversion drop spindle to make everything work out. I planned on running drop spindles anyway, and the price for the conversion spindle was the same as the standard one, so not a big deal.
1972 Blazer
-6 inch lift
-35 inch BFG A/T's
Turbo 350
NP-205
454 BB (for now)
MORE TO COME !!!!!! Now going to 2WD!!!!!
Sold.
I got it back after 22 years and did not even know it !!!
THE STORY HERE
Project Low Down Dirty Rat
ABLAZN is offline   Reply With Quote
Old 09-25-2009, 01:37 PM   #12
Thealien
Thealien's Avatar
Old 09-26-2009, 11:08 AM   #13
TonyJohnson
I picked it up yesterday (heavy...) and it's got new rubber everywhere! Looks like someone rebuilt it just before wrecking their truck. It's got a lot of surface rust from sitting on a pallet outside, but really looks like a great start. I wouldn't hesitate just bolting it up, checking the bearings and running it.
Of course I won't. I'll take it apart, clean it up paint it and reassemble. The shims are missing on the upper a-arm on one side, and the other side looks like it has 10 shims a side... What's with that? I'll look at some trucks this weekend and see what they use. I'll try to get pics on Monday, but I'm out of town all weekend. Later, Tony
Tony Johnson
Old 09-27-2009, 10:31 AM   #14
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
I have a cradle I couldn't give away so I shelved it for future whatever's
The Trans hump is the only thing that I know of, I'll let you know soon if
that is the only diffy since I sold my 4wd chassis and built a 2wd chassis.
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
