Old 08-05-2009, 10:40 AM   #1
fun in dirt
fun in dirt's Avatar
8 lug stud spacing
I found this killer dealer on a set of wheels http://northmiss.craigslist.org/pts/1305110606.html , but don't the 8 lugs for '99 F250 use that 170?mm stud spacing instead of 6.5"? I really wish they would fit...is there any way it could work?
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 08-05-2009, 10:59 AM   #2
ghettoluxury
ghettoluxury's Avatar
Re: 8 lug stud spacing
Correct they are 170mm. The only way it will work is with adapters
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 08-05-2009, 08:22 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I saw one time where a guy that had a sweet 91 F-350 had 02 super duty 8 lug alloy wheels on it. The guy owned a machine shop and machined the wheels and added an offset slug that he also machined and was able to bolt the wheels to his standard truck. It seems like a lot of work though.
Ryan
1969 Chevy milk truck
Old 08-11-2009, 12:47 PM   #4
MickMc
MickMc's Avatar
It seems to me that 6.5 inch bolt diameter pattern is 165.1mm
And 170mm is 6.69 inch
Therefore the difference in diameter is only .095 inch
10 thousandths is not very much
If my math is correct
The more important question will be if the backspacing is correct.
The high offset wheels have a problem clearing early tie rods and brakes and...
Just my two cents
Mick
MickMc is offline   Reply With Quote
Old 08-11-2009, 07:07 PM   #5
LONGHAIR
Just my two cents
Mick
Your metric conversion math is absolutely correct...but the difference is more than you are thinking.
5 millimeters is essentually 3/16"
The difference (english) between 6.5 and 6.69.....is .190 (not .095)
.190 is close enough to 3/16" (.187)
So, what it all comes down to is....does 3/16 matter? IMHO, yes. The wheel "might" physically fit over the lug studs, but the nuts will never tighten properly. They will bind on the edges of the taper before seating. THis will stress the studs.
Of course all of this is moot if the off-set doesn't "work"
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 08-12-2009, 10:58 AM   #6
MickMc
MickMc's Avatar
Yes the difference is .190 but you have to divide by 2 because we are talking about a circle (1/2 as much on each side) so that's how I got .095.
Again all of this math. The real world is something different.
I did bolt on a set of late model wheels on my early model dana 60 no problems with the lug pattern but the offset stopped everything.
10 thousandths is not much in a 6.5 inch diameter space, but are late model truck wheels hub centric or lug centric?
Mick
Old 08-12-2009, 05:29 PM   #7
Blazer1970
Blazer1970's Avatar
Late model GM or Dodge wheels still use the same old 8 on 6 1/2" bolt circle. Late model GM 8 lug wheels will bolt up and work no problem. The issue is with Ford wheels which are 8 on 170mm.
That is almost 100 thou, or a 10th of an inch. That is a lot. Ford wheels will not work on a GM truck without some kind of modification as someone described above. GM truck wheels are all hub-centric, but any 8 lug wheel with the correct bolt circle will work regardless of center hole diameter (as long as the hole is bigger than the hub).
Mick
xxx
Blazer1970 is offline   Reply With Quote
Old 08-11-2009, 05:42 PM   #8
Dieselwrencher
Good input Mick.
Ryan
Old 08-11-2009, 07:18 PM   #9
Blazer1970
Blazer1970's Avatar
If you tried to run those Ford wheels on an 8 on 6 1/2" hub, the lug nuts would come loose on one side of the truck very quickly.
Old 08-11-2009, 07:20 PM   #10
ghettoluxury
I once had a set of 170 mm rims on a 6.5in 8lug chevy (because I was told they were 6.5in) and it had a wicked hop going down the road. So your answer is yes it does make a differance, and belive me when I say this, it is unsafe.
