Old 08-10-2009, 10:46 PM   #1
Eagar1
72 power steering on 63 frame adapter plates?
I have a 63 C20, and I took the entire disc front end from a 72 C20, and now I want to put a newer style like 75 C10 power steering gear on the frame. Anyone have the schematics or specs for an adapter plate? I also want to mount the 75 power booster, any info on that would be appreciated.
Thanks!
Eagar1
Eagar1 is offline   Reply With Quote
Old 08-10-2009, 11:14 PM   #2
daverod
SSN 706
daverod's Avatar
Re: 72 power steering on 63 frame adapter plates?
http://67-72chevytrucks.com/vboard/s...d.php?t=351468
daverod is offline   Reply With Quote
Old 08-10-2009, 11:35 PM   #3
Captainfab
60-66 Nut
Thanks for the plug Dave
If you have any questions Eager1, ask away.....
Old 08-10-2009, 11:43 PM   #4
Eagar1
I sent you an e-mail, I have the tools and ability to build them myself, just not the time, no sense wasting time I need to spend on other issues. I am sure once I get the parts it will be self explanitory. I may need to rustle up a push rod for the brakes or make one. I have the pitman arm on the 75 steer box. I am sure I can use that, and I will drill the holes for the idler arm once I have the geometry from the box. I am dropping a 350 and a 4speed out of an 81 chevy, should bolt right up to the motor mount plates I got from the 72, as it was a 350 4-speed. My 63 was a 6 cyl, 3speed, is why I changed out the complete crossmember, so I had the heavier springs and the reinforcement plates for the upper bolts, and 8 lug discs, I plan on being able to haul and tow with it.
Thanks, and I look forward to your e-mail.
Ron
Old 08-10-2009, 11:54 PM   #5
Eagar1
Sweet looking front end, I have completely cleaned and painted mine satin black as well, although I dont have the nice shiny rotors and other parts =)
Old 08-11-2009, 12:50 AM   #6
Captainfab
60-66 Nut
Email sent.....thanks
Ron
Old 08-12-2009, 08:39 PM   #7
Eagar1
Parts paid for via PayPal, looking forward to just bolting everything ion!
Old 08-10-2009, 11:41 PM   #8
bubba327
HOW long until spring??
bubba327's Avatar
I took advantage of Captain Fab and his July bracket special and though it is not complete yet, is working out perfectly. I am using a 71 disc donor under a 64 C-10. I do not have the steering bracket on yet
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
Old 09-08-2009, 02:53 AM   #9
63sbssbbw
UCA63
63sbssbbw's Avatar
Looks great Ron
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 09-08-2009, 09:04 PM   #10
Eagar1
Thanks 63sbssbbw,
Captain Fab makes some nice Brake booster adapters too, I am going to use one on my 63, and will post those pics too.
Old 09-09-2009, 01:30 AM   #11
Captainfab
60-66 Nut
Thanks for posting those pics Ron
Good looking frame and steering box installation.
I had wondered about the later model intermediate steering shaft, but just hadn't tried it.
Old 09-09-2009, 01:48 AM   #12
Eagar1
It just seemed like they were made for each other
I appreciate all your help and advise John, its nice to find helpful people these days.
Old 09-12-2009, 03:06 PM   #13
Eagar1
Just thought I would post pics of how the Idler arm and centerlink ended up.
with no shocks and the arms at full drop, and with the centerlink level with the frame, the centerlink almost touches the crossmember. It moves away as it goes through the steering lock to lock, and will move away when it is on the ground with some weight on it.
