![]() Join Date: Sep 2006
72 power steering on 63 frame adapter plates?
I have a 63 C20, and I took the entire disc front end from a 72 C20, and now I want to put a newer style like 75 C10 power steering gear on the frame. Anyone have the schematics or specs for an adapter plate? I also want to mount the 75 power booster, any info on that would be appreciated.
Thanks! Eagar1 |
SSN 706
Re: 72 power steering on 63 frame adapter plates?
![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by daverod; 08-10-2009 at 11:15 PM. |
60-66 Nut
Thanks for the plug Dave
![]() If you have any questions Eager1, ask away.....
HOW long until spring??
![]() Join Date: Mar 2009
I took advantage of Captain Fab and his July bracket special and though it is not complete yet, is working out perfectly. I am using a 71 disc donor under a 64 C-10. I do not have the steering bracket on yet
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
I sent you an e-mail, I have the tools and ability to build them myself, just not the time, no sense wasting time I need to spend on other issues. I am sure once I get the parts it will be self explanitory. I may need to rustle up a push rod for the brakes or make one. I have the pitman arm on the 75 steer box. I am sure I can use that, and I will drill the holes for the idler arm once I have the geometry from the box. I am dropping a 350 and a 4speed out of an 81 chevy, should bolt right up to the motor mount plates I got from the 72, as it was a 350 4-speed. My 63 was a 6 cyl, 3speed, is why I changed out the complete crossmember, so I had the heavier springs and the reinforcement plates for the upper bolts, and 8 lug discs, I plan on being able to haul and tow with it.
Thanks, and I look forward to your e-mail. Ron |
Sweet looking front end, I have completely cleaned and painted mine satin black as well, although I dont have the nice shiny rotors and other parts =)
#7 | |
60-66 Nut
Email sent.....thanks
![]() Quote:
Parts paid for via PayPal, looking forward to just bolting everything ion!
60-66 Nut
Your parts shipped out today Ron.
Thanks for the purchase ![]()
Got em outa the mail today, they look great, will post pics when I have em installed, thanks!
As promised, here are some pics of Steering adapter plate install. Cut my steering shaft back 1 3/4 per instruction. Lined up as per the measurements, got the pitman arm bolted on, made sure the box was in line with the shaft. Clamped the plate in place, tacked to frame with some ugly welds from my POS craftsman wirefeed. Drilled holes, painted. I decided to keep the original steering column for now. I cut the lower hollow shaft off of the 75 column, and used it to slip over the original shaft, perfect fit, then drilled a couple of holes in the hollow shaft so I can put 4 plug welds in it for strength.
Still have to line up the idler arm and bolt it in place. Starting on the Power brakes next and will start a new thread with those pics. Captain feel free to link or add these pics to your for sale post. |
UCA63
Looks great Ron
T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
Thanks 63sbssbbw,
Captain Fab makes some nice Brake booster adapters too, I am going to use one on my 63, and will post those pics too. |
60-66 Nut
Thanks for posting those pics Ron
![]() Good looking frame and steering box installation. I had wondered about the later model intermediate steering shaft, but just hadn't tried it.
#15 |
It just seemed like they were made for each other
![]() I appreciate all your help and advise John, its nice to find helpful people these days. |
#16 |
Just thought I would post pics of how the Idler arm and centerlink ended up.
with no shocks and the arms at full drop, and with the centerlink level with the frame, the centerlink almost touches the crossmember. It moves away as it goes through the steering lock to lock, and will move away when it is on the ground with some weight on it. |
