Old 01-13-2003, 02:02 AM   #1
chevluvr
67 bod on 77 frame
Does anyone have any info on changing a 2wd 67 body onto a 77 4x4 frame. Do the body mounts match up on the cab and bed? Any information and suggestions will be helpful. Thanks!
chevluvr is offline   Reply With Quote
Old 01-13-2003, 02:08 AM   #2
dtlilly
dtlilly's Avatar
Welcome to the board
I'm not an expert, but I believe a 2wd cab will not work on a 4x4 frame. The 4x4 cab has a higher center hump to allow for trans and T-Case. If I'm wong, maybe someone else can shed some light on the subject.
dtlilly is offline   Reply With Quote
Old 01-13-2003, 08:22 AM   #3
Showme-K-20
You can cut out the floor at the hump and replace it with a high hump. Check out Mudder67's truck. It's on a later model frame.
Bob
Showme-K-20 is offline   Reply With Quote
Old 01-13-2003, 05:16 PM   #4
BadHabit
It can be done
Chevluvr...It can be done with a lot of patience. I placed my 2WD 70 shortbed fleetside on a 76 4WD shortbed frame. You do not need to cut the rear of the cab, however, you will need to make your own front cab mounts and core support mounts. I used 3" body lift blocks under bed which lined it up perfect with the cab. There is no way around elevating the bed off of the frame unless you were to figure out a way to cut rear of cab. My cab was perfect and rust free so that was unthinkable to me. High hump cabs are only high in the front of cab and are absolutely no different behind the floorpan area. Hope you have some metal working tools (IE: grinders, drills, torch/plasma cutter and welder). I will try to get some pics posted for you asap. BadHabit.
70 Chevy SWB 4x4 350/350/203.
02 Honda VTX.
98 Honda XR400.
88 Honda prelude Si 4WS.
99 Nissan Maxima SE.
& one spunky little Jack Russel.
BadHabit is offline   Reply With Quote
Old 01-14-2003, 03:36 PM   #5
Mudder
Mudder's Avatar
cab mounts
i used all the 67's cab mounts and a low hump floor. did not cut the cab.
Mudder is offline   Reply With Quote
Old 01-14-2003, 03:38 PM   #6
Mudder
Mudder's Avatar
One on the important things is getting the cab mounted back away from the distributor to were you can get it out if needed. that pic up there is a front mount.
Old 01-15-2003, 09:51 PM   #7
orionwy2002
Mudder, you should
put a how to list on this swap on a web site or something! You seem to be the expert everybody asks. If i can figure out how to attach stuff i'll post the pictures you sent to me the other day.
Orion
80K10Scottsdale 350/th350/205 d44/14bff locked 35's
97 blazer 4x4 daily driver
orionwy2002 is offline   Reply With Quote
Old 01-16-2003, 03:47 AM   #8
red450ih
red450ih's Avatar
photos
I'd like to see the photos as well. I have a good 77 4WD frame that I'd like to stick under a older truck. What radiator support brackets did you use, 67 or mid 70's ones on the frame already? Did you have to move the rear axle? I read there is a wheel base difference between 67-72 and 73-87.
My email:
Red806IH@aol.com
Thanks,
Keith
red450ih is offline   Reply With Quote
Old 01-16-2003, 03:49 AM   #9
Mudder
Mudder's Avatar
The 67 front clip is bolted right to the mounts on the frame. I can send you the pics if you pm me your addy. Never mind I just say it up there LOL. Do you want me to send them?
Old 01-16-2003, 04:02 AM   #10
Mudder
Mudder's Avatar
I also have pics of my rear gas tank and different filler tube options if ya want. Let me know.
Old 02-08-2003, 09:45 PM   #11
racerjim
hey mudder couldyou shoot some pics my way also?
i have an 81 stepside that im coverteing to 69 and any info would help.
thx.
81 chev 1/2ton 4x4,
4"lift and 38" super swampers.
soon to become a 69.
racerjim is offline   Reply With Quote
Old 02-12-2003, 10:24 PM   #12
greenhorn male
greenhorn male's Avatar
Hey Mudder I'd like to see pics of your rear gas tankand filler tube options...Thanks
Lzapa007@attbi.com
03 Tahoe
72 GMC Super Custom 2500 Custom Camper, my reliable workhorse. Dual gauged tanks, dual battery trays.
greenhorn male is offline   Reply With Quote
Old 02-13-2003, 03:45 AM   #13
Mudder
Mudder's Avatar
Have I missed anyone that wanted these pictures?
Old 02-13-2003, 11:12 PM   #14
red450ih
red450ih's Avatar
I never got any.
Red806IH@aol.com
Keith
Old 02-14-2003, 03:51 AM   #15
Mudder
Mudder's Avatar
Red they are on their way.
Old 02-21-2003, 08:21 PM   #16
bs300ex5
mudder... hey hit me up with those pics too at bshing5@aol.com
LOOKING FOR A 1973 - 1987 FULLSIZE CHEVY 4X4 WETHER IT'S A RESTORATION PROJECT OR READY TO RIDE PLEASE PM ME!
bs300ex5 is offline   Reply With Quote
Old 03-03-2003, 03:12 AM   #17
71 BIG RED
YES PLEASE, SOME PICS. DOING A 68 LONG BED STEPSIDE TO A 198? 4X4 THANKS.CHAD
big red 71
71 BIG RED is offline   Reply With Quote
Old 03-03-2003, 01:39 PM   #18
Mudder
Mudder's Avatar
Need an email Big Red....
Old 03-04-2003, 01:07 AM   #19
YankeeWhite
Me too, me too! derphoenix@hotmail.com
YankeeWhite is offline   Reply With Quote
Old 03-25-2003, 01:21 AM   #20
Mudduck72
old post
i need some pictures of your swap 77 frame to 70 chevy body thanks
69 chevy 4x4 restored 70 blazer with one ton axles $4000 69 chevy 4x4 project $1200 72 ford 4x4 project $1500 58 chevy 1 ton dually $1200 Lots of motors and tranny t cases
Mudduck72 is offline   Reply With Quote
Old 03-26-2003, 08:23 PM   #21
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
pics
Hello mudder, would it be possible for you to send me some of those pics as well? Thank you.
my addy:
2low69@earthlink.net
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
