Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-12-2009, 06:52 PM   #1
Hart_Rod
Hart_Rod's Avatar
Boost gauge question....
I just installed an Autometer 3301 boost/vacuum gauge on my 383 with a vortech supercharger. I have a question about normal operation of the gauge. At a steady 60 mph/2800 rpm/4psi boost, the needle flucuates so fast you can barely read it (+/- 3 psi). I'm new to superchargers and this is my first boost gauge, but that just doesn't seem right. I installed it exactly like the autometer instructions said and used the port that Vortech recommended. Do I have a leak? Any suggestions? OBTW, it's in the in the same port that goes to my MSD 6BTM box. Thanks in advance.
R/
Hart_Rod is offline   Reply With Quote
Old 10-12-2009, 08:50 PM   #2
1FAST68
Re: Boost gauge question....
I have done a bunch of blowthru procharger stuff. Where exactly is the gauge hooked to on the engine. If it is showing 3psi driving normal sounds like you have it above the carb, it will never show vacuum.
What is the setup? carb, fuel inj, and does it have bypass valve.
68 chevy truck
ls3, 418ci, pump gas 10.81@121.8 all motor. 1.47 60ft
70 suburban
350 tbi swap, 700r4, work in progress
1FAST68 is offline   Reply With Quote
Old 10-12-2009, 09:04 PM   #3
Hart_Rod
Hart_Rod's Avatar
It's connected between the supercharger and the carb (outupt of the supercharger). I'm not to worried about it not showing vaccuum, but should the need be bouncing around so erratically?
Old 10-12-2009, 09:12 PM   #4
1FAST68
probably, it could be compressor surge sounds like there is no bypass valve
I put the boost gauge on the intake manifold so I could see the pressure in the motor and not above the carb. Also I used a bypass valve that dumped boost when driving normal so the supercharger was not is a bind.
68 chevy truck
70 suburban
Old 10-12-2009, 09:34 PM   #5
Hart_Rod
Hart_Rod's Avatar
What did the bypass valve do for your drivability? I was told I didn't need one, but what would you sugges? My MSD is connected to the same line, what problems will/could that cause? Do you have some pictures of the bypass valve and where you connected the boost/vac line? Thanks for all the information.
R/
Old 10-12-2009, 09:54 PM   #6
1FAST68
R/
The bypass valve helps ease the load on the supercharger under normal driving, it also helps flooding issue when you suddenly let off the gas. The valve should be located between the blower and carb, it operates off of vacuum, so when driving normal you have vacuum and it opens the valve, dumps unwanted boost. When you floor it you loose vacuum and it closes and sends all the boost in the engine.
As far as the MSD boost retard line, it needs to be on the intake also, otherwise you will be retarding the timing under normal driving because it will see boost between the carb and blower.
Another note, fuel pressure should rise with boost, so you should have a fuel pressure regulator with a vacuum line connected between the carb and blower.
I will have to email you pics, they are too big to load here if you want.
68 chevy truck
70 suburban
Old 10-13-2009, 09:36 PM   #7
Hart_Rod
Hart_Rod's Avatar
OK, I hooked the gauge up to the same port that the tranny modulator is connected to. The gauge now is more stable and shows about 14 hg of vaccuum at ide. I took it for a test run and and got on it a couple of times, but nothing real hard. The gauge would go to zero but I don't think it went positive (boost) for very long. Is this geting closer to the way it should act?
Old 10-13-2009, 10:03 PM   #8
1FAST68
Yes, you will have to go wot for it to show boost. Now you are getting a true reading of what is in the engine and not on top on the carb.
68 chevy truck
70 suburban
Old 10-13-2009, 10:21 PM   #9
Hart_Rod
Hart_Rod's Avatar
Cool. Where did you get your boost adjusted fuel pressure regulator? I think that is the last thing I need to add to have all the parts in place prior to taking it to be dynoed tuned.
R/
Old 10-13-2009, 10:39 PM   #10
1FAST68
I have used a mallory 4309 regulator for below 15lbs of boost, but I don't know what your fuel pump is. Hope not a holley blue style!!
My 1rst setup I used a mechanical edelbrock pump that had the clockable bottom. I drilled and tapped the top of the pump for a 1/8 nipple and ran a vacuum line to it. It would raise fuel pressure with boost then, but I only had 8lbs of boost back then.
If you run your fuel pressure at 7lbs and have say 10lbs of boost that means you will need 17lbs of fuel pressure and another 5 to overcome pumping loses and g force in the line, so 22lbs of fuel pressure at wot.
68 chevy truck
70 suburban
Old 10-13-2009, 10:54 PM   #11
Hart_Rod
Hart_Rod's Avatar
I currently have a holley black pump and am running 10 AN lines front to rear. PSI is set around 7.
Old 10-14-2009, 08:38 AM   #12
Alex1
Alex1's Avatar
Nice set up, is it the YSI? or an S or T trim?
I prefer the Vortechs to the PROCHARGER - more reliable. Do you have better pics of your set up? I'm sure the guys here would like to see.
I noticed you have a blow through carb - do you have a wideband set up? I thought one was supposed to use a regular carb in the enclosure - the blow through cars are for the set ups where the carb is not enclosed.
But if it works..
Alex1 is offline   Reply With Quote
Old 10-14-2009, 01:22 PM   #13
Hart_Rod
Hart_Rod's Avatar
How much pressure will the black pump make?
I would call vortec and tell them the serial # on the blower, they should have a record of what pulley combo it was sold with and what boost it should put out. Also ask them about the fuel system, I am not that familiar with the vortec box. I assume it works the same a the procharger hats I used to run but I don't want to assume anything on your engine and give you the wrong advice.
I hope I have been helpful. I have had 6 centrifugal blower setups and learned the hardway.
From the holley website:
http://www.holley.com/12-815-1.asp
Compatible with alcohol or methanol fuels
Flows 140 GPH (free flow)
Flows 120 GPH at 9 PSI
Maximum pressure is 14 PSI
3/8” NPT inlet and outlet ports
Fuel pressure regulator is required (Recommend Holley P/N 12-704 for gasoline & P/N 12-707 for alcohol)
Provides constant fuel flow with no pulsation
Has externally accessible pressure relief valve (max 14 PSI)
Rotor/Vane pump design is more tolerant of contaminated fuels
Not designed or recommended for use with fuel injection systems
I'm still waiting for Vortech to get back with me. Their customer service suxs......
But if it works..
What's a wideband setup? It's an S trim. The truck already had the supercharger in it when I bought it. I don't know about the blow through carb, this is my first S/C and I'm just trying to make sure everything is setup correctly so I don't break anything. If you go to the following link you can read the story behind the truck as well as view a bunch of photos:
http://67-72chevytrucks.com/vboard/s...d.php?t=358692
R/
Old 10-14-2009, 06:16 PM   #14
Alex1
Alex1's Avatar
R/
A wideband 02 sensor, tells you if your lean or rich - it's a good tool for tuning, although you should always read your plugs. But it can help you out certainly if you're tuning it yourself - because you don't want to be lean under boost.
Definately worth it.
Old 10-14-2009, 06:34 PM   #15
1FAST68
Alex1 is correct about the wideband and reading your plugs. Wideband setups are expensive tho, if you were here in east tx you could borrow mine.
I don't think your fuel pump is going to cut it. Unless you only have 2-3 psi of boost.
68 chevy truck
70 suburban
Old 10-16-2009, 10:20 AM   #16
Hart_Rod
Hart_Rod's Avatar
Does this just install in the exhaust like a factory 02 sensor?
Thanks for the offer on the WB, . So you think the fuel pump just won't be able to apply enough pressure? What pump do you recommend? This is just a daily driver with an occassional weekend trip to the drag strip.
I finally got in touch with Vortech, :-/. They said I should have everything connected to a vaccuum source as you 2 suggested, . I've got everything connected to the same port that the tranny modulator is connected to right now, but I will rework everything the next time I pull the carb enclosure off. I think I found some manifold ports, but I can't get to them right now. They also said I needed the bypass valve if I was getting more tha n 5-6 pounds of boost. When I asked how much boost this setup should be putting out, they couldn't tell me and said they were all different, . So, what's the best way to figure this out without breaking anything? They also recommended getting a pressure or boost adjusted FPR. I'm assuming the signal for this will come from the same port as the boost gauge? I didn't realize all this supercharger stuff was so complicated, , .
Old 10-16-2009, 02:32 PM   #17
Alex1
Alex1's Avatar
Yes the wideband threads in like a regular 02 - there will be a box or display that you will have to wire in though.
Old 01-18-2014, 09:33 PM   #18
70blackfish
Talking Re: Boost gauge question....
I need to read all this.......a little later
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
