Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-12-2009, 09:34 PM   #5
Hart_Rod
Hart_Rod's Avatar
Re: Boost gauge question....
Originally Posted by 1FAST68 View Post
probably, it could be compressor surge sounds like there is no bypass valve
I put the boost gauge on the intake manifold so I could see the pressure in the motor and not above the carb. Also I used a bypass valve that dumped boost when driving normal so the supercharger was not is a bind.
What did the bypass valve do for your drivability? I was told I didn't need one, but what would you sugges? My MSD is connected to the same line, what problems will/could that cause? Do you have some pictures of the bypass valve and where you connected the boost/vac line? Thanks for all the information.
R/
Hart_Rod is offline   Reply With Quote
