Project Optimus Prime
I put in some rhino liner in the bed of my truck about a month ago and followed all tha steps when installing to a tee!! and it turned out PERFECT!!
84 SWB work in progress ![]() ![]() 89 burb 1500 (parts pig) LOL ![]() 08 ford focus (I know, I know) Wifes car ![]() "I said it b4 and i'll say it agian wiring is my worst enemy":devil: ![]() |
It'd be alot cooler if you did
Re: N E body in here got Rhino Liner in there trucks??
You did this yourself? Sounds like it wasn't prepped properly I've used the roll on stuff with pretty good success. Actually I've worn through it before it flaked off.
Yea I did do it myself and like i said i literially went out of my way to follow ALL tha steps perfectly so this would not happen!! I already 4got all tha steps but i prepped, prepped, and prepped everything sanded tha bed cleaned it with a solution, taped everything off and everything and now im really dissapointed with the end result!
When I turned 18, I bought a brand new 2000 S-10. I used the duplicolor roll-on, and it did the same thing. Frustrated, I scraped it all off and tried it again. The second time, I used a 5" angle grinder with scotch-brite pads and removed most of the paint. I then applied the bed coating, using 1 1/2 gallons (it was a step side). I can't remember exactly how many coats I put on, but I know how much I used. I then waited a week, or so, to let it cure, and it still hasn't chipped. IMHO, it is just like a paint job, prep is everything. Make sure every square inch is scuffed up, and wipe down with paint thinner before applying. Any dirt, dust, grease, water, or smooth paint will not allow it to adhere properly. Also, wear gloves to keep your hands from drying out and fingerprint grease off of it. You could possibly rescuff the areas that it did peel, but that will become a never ending process, so I would just try again, at least with the bed floor and tubs.
I have car A.D.D.
I agree with what has been said here. The key to bedliner sticking is the "mechanical adhesion", in other words...it's being able to get into some good scratches and hold there. If you did not have it sanded coarse enough, or completely enough, it will not stick.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
I sanded it first with an angle grinder with 100 grit then with 80 grit THEN sanded it last by hand with 100 grit and 80 grit agian the whole prep in tha bed was started at 9 o' clock and tha prep was finished at 2 or 3 o'clock so a good 5 to 6 hours was tha prep including sandind with both grits with an angle grinder and then agian to finish it off by hand with tha same grits then prepped agian with solution wearin gloves and making sure not to touch n e thing with my hands. waited double tha time 4 it 2 cure and idk y it didnt work!
The stuff you used sucks. What more is there to say?
![]() Last edited by smashingchuck; 11-20-2009 at 01:35 PM. |
LMAO!!!! thats exactly wut i was thinkin!!LOL
Under Construction
i'm pretty sure 40 or 60 grit should have been used. I doubt 80 grit is coarse enough for proper adhesion. I am not saying you didnt follow instructions, but 80 grit does not leave enough scratches in my opinion.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 11-20-2009 at 01:57 PM. |
yeller
So you installed the name brand Rhino Liner yourself...or did you use an over-the-counter application and you are referring to it as Rhino Liner? From what I have seen and heard, the over-the-counter stuff pretty much sucks. I thought the only way to get a Rhino Liner or Line-X liner was to go to a dealer and have them installed.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Heath u very well may be right that could of been it, but it just seems like it was good enough i guess..dunno. and big block73 I was just referring to it as rhino liner Im sorry I think cause its tha most popular one tha name just comes to me it was actually a complete kit i bought from HERCULINER
#12 | |
1954 Chevy 3600 - 235, 4-spd 1986 Chevy Suburban - 350, 700R4 |
Yea prolly so thats 1 of tha things i was thinking might of happened 2. who knows?? O' well u win some and u lose some!!
Yeah sounds like it didn't stick to the bed that good.My uncle is a roofer his truck has had a line-x liner for 6 years it still looks good.
#15 |
Born a Chevy Man
I do not like the looks of most of the Rhino liner installs as much as I do the Line-X. I have Line-X in my truck and had it installed in Nashville and looks perfect. Also had Line-X Extra protection installed and has not faded at all. Looks as good as the day it was installed. I did not know you could get Rhino in a can. My two cents is to go with Line-X.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66 *1986 Chevy SWB Silverado *1984 Chevy Longbed Silverado New Kia Sportage (Wife's car and she loves it) ![]() ![]() If you can read this, YOU NEED TO THANK A TEACHER! If you can read this in ENGLISH, PLEASE THANK A SOLDIER! ![]() GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS |
#16 |
Thanks 86swb i will most likely go wit them in tha future.
Thanks everybody
#17 |
I have heard good things about the UPOL Raptor spray in bed-liner....never used it my self though...
http://www.autobodytoolmart.com/u-po...s-p-15123.aspx
#18 |
Born a Chevy Man
It is worth getting the Line-X Extra Spray in protection also. Keeps your spray in bed liner looking new. On reviews, Line-X comes in as the one to get.
#19 |
in the 79,i have a spray in done by the local chevy dealer.it resembles a line x.iv'e had rhino and line x both in some of my daily drivers.i prefer the look of linex.the rhino look's like cottage cheese dyed black.i suppose it depends on who's doing the application.i know they scratch the crap out of it with i believe 40 grit.to give it some bite.i get lot's of compliments on the 79 liner which i had put up on the rail.anything you see is a reflection,the liner is perfect.
" Never look up a dead dogs butt." ![]() |
#20 |
![]() Join Date: Aug 2005
The do-it-yourself Rhino Liner is garbage. Prep all you want, it'll still chip and peel off. I used it in my 98 that I had and the same happened to me. It just doesn't hold up. I am trying the Duplicolor liner this time. We'll see what happens.
Also, I was going to look into Al's Liner. It is a do-it-yourself spray in for less than half the cost of Line-X. Looks to be about $150-$175 for 1 gallon of liner and the spray gun. Not bad in my book if it turns out to be a good product.
'73 C-30 3+3 Dually 454/TH400 '74 Fleetside 350/TH350 (SOLD) '69 Nova 350/TH350 (project FOR SALE) '63 Nova 305/TH350 3.73 posi (the wife's project) Last edited by bad_burb; 11-23-2009 at 09:36 PM. |
#21 | |
![]() ![]() Last edited by joe231; 11-23-2009 at 10:00 PM. |
#22 |
in 2006 i took a brand new truck to the rhino liner dealer gave him my 500 bucks he did a great job which was guaranteed for the life of the truck.while im all for saving money in this case your not saving anything.some things are best left to professionals.i do agree that line-x looks better but rhino works great anything i put in that bed stayed put nothing slides around well on rhino liner its thick also.
#23 |
laying low
![]() Join Date: Mar 2001
A dealer applied Rhino Liner came in my 97 GMC. After having one of those drop in plastic liners in another truck and hated it cause most everything slides all over the bed I am very pleased with the Rhino. I hauled a lot of heavy, oilly, sharp cornered stuff and never did it peel or gouge or fade. My truck sits outside everyday too. I hate that it's so expensive but in my opinion it is worth it. I've not seen any others I like better.
I'm not sure but the Rhino's may be available in matching body colors too. Anybody got one?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 11-23-2009 at 10:44 PM. |
#24 |
I used Herculiner about 6 years ago. The stuff really held up nicely against lumber, firewood, and weekly dump runs. Sold the truck 2 yrs later, but it held up well for those 2 years. only drawback that I experienced was how course and abrasive it came out. It could draw blood if you leaned against the bedrails just right
#25 |
Sb 400 club
I have herculiner on my truck and it seems fine.
Thing to keep in mind is the U/V protection. Drulack has great UV protection and will last even longer. I prepped mine with 40 grit by hand and just took my time.
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
